nology plug wires
Old Feb 8, 2007 | 04:56 PM
myblackC5's Avatar
myblackC5
Default nology plug wires
i just bought a set of nology silver spark plug wires, also there silver plugs. well i was looking at them and discovered therer non resistor, wires and plugs...........anybody tryed them before? will they work? summit has a clearance on the two items 245 dollars for both. don't tell me i'll drive around with the same amout of static as when the war department is with me!
Old Feb 8, 2007 | 07:05 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Never used them BUT,,,,,,you could have most likely have spent your money on a better performamance up-grade. You will most likely gain little or no HP unless your other wires were causing issues.
If there spirial wound cores, they will have inductance which will help eliminate RFI and EMI.
BC
Old Feb 8, 2007 | 09:09 PM
Greg_E's Avatar
Greg_E
I've never used them, but from the pictures I've seen, they have a braided shield wire that you connect to a good ground. That should keep the noise down.
Old Feb 8, 2007 | 09:21 PM
BMERETR's Avatar
BMERETR
Keep The Shiny Sine Up
I have had them in my car now for 3 years
ok wires no problems
the plugs on the other hand
a big price for not mutch
and they are very noisy with the stock radio
cd player had not mutch of a buzz but the am/fm real noisy
i found that the factory plugs worked just as well and took care of all the noise
i might be giving up some mythical performance but i cant tell
sts twin with 600rwhp
hope this helps
Old Feb 8, 2007 | 10:43 PM
Mike94ZLT1's Avatar
Mike94ZLT1
You spent $245 on plugs and wires????
Old Feb 8, 2007 | 11:08 PM
Humanoid 2.0's Avatar
Humanoid 2.0
St. Jude 15 Year Donor
Cruise-In VII Veteran
St. Jude Donor '05 thru '19
Silver is not very durable for plugs, you wont get too many miles out of them.
To nology plug wires
