P, C and B codes galore!
- P0171 fuel trim lean bank 1
- P0174 fuel system lean bank 2
- P1431 fuel level sensor performance
- C1288 steering sensor circut malfunction
- B2723 pass key detection circut short
If I were you I would read the codes my self and see what the real story is:
This is the absolute best C5 Diagnostic Trouble Code (DTC) web site!!!
http://www.corvettedoctor.com/Code_Main.html
http://www.corvettedoctor.com/index.html
Go to “technical data base” and then to “Corvette ECM Computer Codes”. Then select your year car. Read the instructions and then scroll down to the "READ MORE" window to view the code definitions.\
Here is another very good site:
http://www.obd-codes.com/trouble_cod...d-ii-codes.php
Make sure to include the H or C suffix!!
Write down and post your DTC’s Then clear them ALL!
Sound effects are cool too!
If you CLEAR all the codes and take the car for a short drive, you will see if any of the DTC's come back. Post the new results and we can help you fix the issues. If there serious enough or effect emissions, you will get a Check Engine Light (CEL). Was the CEL on when you took it to the dealer??
BC
BC
So due to the fact that I just recently were just married and purchased a house here on Long Island, I need to address the issues that are the higher priority ones and less expensive. thoughts?
P0171 H
P0174 C
P1431 H C
C1288 C
B2723 H
Recheck and list the letters after the code numbers.
We will see if we can get them fixed.
BC
- P1043 H C
- P1431 H
- P1571 H
- C1226 H
- C1288 H
- B2252 H
- U1096 H
- U1064 H
- B2283 H
- B2285 H
- C2120 H C
I have NO IDEA what a QC 234421 is!
I recommend that you disconnect your battery and clean the terminals. There is a ground next to the battery G-104. It MUST be clean and tight! I would check for any evidence of a past battery acid spill. Look at the wiring harnesses under the battery. See if there nasty and if there are any white deposits on them or rust on the frame.I would also check and clean all the other grounds .
Check out this post:
http://forums.corvetteforum.com/showthread.php?t=896875
Bill
BC
C2120 TPM System Malfunction (No Sensors Received).
Don't know what the othe "C" code is. I would follow Bill's instructions and also check to if your battery is fully charged.
Lots of electrical gremlins, when battery is not working right.
Bill
BC
How much did they charge you to repalce the harness and clean up the acid spill?
Is the car running correctly??
BC
BC
not responding well. I guess one thing at a time...youre a great help! thanks for everything so far.
When is it most sluggish?
If it were me, i would rip off the cats and take it for a ride!!!
