Tire sizing question..pls help
Old Feb 10, 2007 | 04:06 PM
RandyC5's Avatar
RandyC5
Default Tire sizing question..pls help
Hey guys,
Long time no see!! I've been looking into buying some new rims and tires for the vette now that shes no longer my daily driver...that title goes to my new TT600
I've heard a little controversy over tire and rim size and kinda wanted to get the tech guys opinions on the whole setup.
Now i don't plan on racing her so i'm not to worried about setting up everything for that.
Ok so heres the theory i'm working with:
My stock tire height (99 FRC) is:
Front: 245/45/17 25.68" Tall
Rear: 275/40/18 26.66" Tall
So if moved up to the following the general height would still be the same right (atleast within 1 inch).
285/35/18 25.85"
295/35/18 26.12"
But i was thinking....if i were to go with 295/35/18 all the way around i would be able to rotate the tires and get more use out of them...like you would on a normal car.
But i'm curious as to how bad that would set the car off in looks...ie the height offset would be kinda strange. Anyone know what this would look like or how easy it would be to fix...maybe lowering the back end?
Thanks ahead of time for any info....and try not to flame me as i did use the search button ahead of time.
Randy
Old Feb 10, 2007 | 04:22 PM
LoneStarFRC's Avatar
LoneStarFRC
The main thing I see there is the very large fronts. I'm thinking you may run into suspension/frame tire contact problems when turning. Not sure if you'll be able to get away with 285s. You don't mention much as to which wheels, etc. The amount of offset and/or backspacing can have a major impact on what you're trying to accomplish as well. Most of the time it's the fronts that can cause the most issues due to wheel turning (right/left) and wheel travel (up/down) and you will only be able to go just so wide before these things come up.
I'm running 18" front/rear but I have 265s in front and 295s in rear. Also Im using 9.5" width wheels in front and 11" width wheels in back.
HTH,
Robert
Old Feb 10, 2007 | 04:25 PM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
I first off would not think that would look very good and secondly the 295/35x18 is too big for the front...
You would have problems I'm sure if driving under normal street conditions..
If you are NOT using the car as a daily driver any longer maybe rotating tires should not be a concern.... just a thought
Old Feb 10, 2007 | 04:57 PM
eschantra's Avatar
eschantra
Running the same size tire on the front and rear would make the car look disproportional IMO and may cause fits with the ABS computer, which was designed for a larger diameter rear tire. You could run a higher profile tire in the rear than the front, maybe a 275/35 tire in front with the 295/35 rear, but I still think it would look better with a 1" bigger rim on the rear. 18/19 here
Old Feb 19, 2007 | 06:05 PM
RandyC5's Avatar
RandyC5
Touche!!! lol
Ok so this is what i'm looking at now as far as rims go...
Chrome Motorsport Z06s
17 x 9.5 (front)
18 x 10.5 (rear)
My next question is what size rubber i need to be putting on these?
I was looking at something along the lines of
275/??/17 (Front)
315/??/18 (Rear)
I don't need the Mich Pilot Sports as they are a bit on the high side for a "cruiser"....granted i'm sure i don't REALLY need 315s at all, but i love the way they look...
Any ideas on good places to get the rims or rubber would also be appreciated as the cheapest i've found the rims is on ebay for $875 shipped. As for the rubber i'm told Tire Rack is the place to go?
Anyway, as always i appreciate any help you guys can give me!!
Old Feb 19, 2007 | 11:54 PM
wamara's Avatar
wamara
Cruise-In II Veteran
275/??/17 (Front)
315/??/18 (Rear)
With the Z06-sized front wheel, you would normally run a 265/40-17 or 275/40-17 (either is OK). Your problem will be with the rears you want. I don't think there is a tire made that is 315/35-18, and a 315/30-18 (which does exist) is too small a diameter in relation to the fronts. You either need to go with a 335/30-18 (and will need a wider rim than 10.5", along with possible rubbing issues), or drop down to a 305/35-18 (very, very limited tire choices), or decide that a 295/35-18 really isn't so bad after all, as it is readily available from many mfrs, and is a lot cheaper to boot.
Old Feb 20, 2007 | 11:35 AM
SilvaDragon's Avatar
SilvaDragon
I ran 275/40/17s all around on 5-spoke ZR1-style rims, and thought
the car looked great, and didn't have any issues with ABS or
active handling (and this was for track tires, so I know the active
handling was working)
Sure makes your track tire dollar go farther when you can rotate!
Old Feb 20, 2007 | 09:23 PM
JonLT4CE's Avatar
JonLT4CE
Hey guys,
285/35/18 25.85"
295/35/18 26.12"
Randy
In case no one has seen this: http://www.miata.net/garage/tirecalc.html
It's a tire size calculator. Very handy.
Old Apr 12, 2007 | 01:22 PM
RandyC5's Avatar
RandyC5
OK so i talked to one of the tire guys at Tire Rack today and he told me that...
275/40/17 would be good for the front, but that a 295/35/18 would be almost a full inch shorter in the rear than comes with stock...thus throwing off the ABS.
Have you guys had any problems with this at all?
The setup he suggested was
275/40/17 front
285/40/18 rear
Should i be concerned that the 295/35/18 will actually throw off my ABS..
My car is a 99FRC btw for reference.
Again i appreciate the help guys
Old Apr 12, 2007 | 03:08 PM
electronbluec5's Avatar
electronbluec5
The 295-35-18 is the stock rear Z06 size from 2001-2004. I would say the guy at TireRack needs to review his math. I have been running 275-40-17 fronts and 295-35-18 rears for two years WITHOUT ONE issue. That is the tire size I would go with unless you find the front tire you want in a 265-40-17. If you find the tire you want in the smaller size go with that.
I just did the tire size calculator and I cam up with about a half inch difference in the diameter of a 275-40-18 and a 295-35-18. In case you aren't aware those are the stock rear sizes for Coupes/FRC/Verts and Z06s respectively.
Greg
Old Apr 12, 2007 | 03:43 PM
Got uid0's Avatar
Got uid0
St. Jude Donor '17
Greg
i run 275 40 17 and 295 35 18's also
No problems Actually much better solid drive now. Less over steer
I went with the F1 super car tire others have gone with the G3's if you want a bit cheaper tire.
you do not want 295's all the way around
Go with what we know works
Old Apr 12, 2007 | 03:57 PM
electronbluec5
Something I meant to mention earlier. I know several guys that go with 295-35-18 tires on 18x10.5 Z06 wheels all the way around but they only use that setup on the track. The people I have talked to have not run into any issues running that setup but they don't turn their cars lock to lock very often on a track. If you go with a wide setup like that you will have some pretty bad scrubbing issues on full steering lock and high suspension load. I would say no more than 275 fronts without additional offset.
Greg
Old Apr 27, 2007 | 03:44 PM
brandtdavis's Avatar
brandtdavis
what about 245/45/17s stock runflats and 275/35/18s BFGs any problems here on stock wagon wheels??
To Tire sizing question..pls help
