Removing gas tank
Old Feb 11, 2007 | 10:18 PM
c5runs's Avatar
c5runs
Default Removing gas tank
can someone tell me how I would go about removing the right side gas tank behind the passenger side? I took out the bolts and shield, but have no idea how I'm suppose to get access to the cross over hose. tips and advice would be great.
Old Feb 11, 2007 | 10:25 PM
CorvetteTechInc's Avatar
CorvetteTechInc
From the service manual. Hope it helps.
Disconnect the negative battery cable.
Relieve the fuel system pressure. Refer to the Fuel Pressure Relief Procedure .
Drain the fuel tanks. Refer to Fuel Tank Draining Procedure .
Raise the vehicle. Refer to Lifting and Jacking the Vehicle in General Information.
Remove the right rear tire and wheel. Refer to Tire and Wheel Removal and Installation in Tires and Wheels.
Remove the fuel tank shield mount nut (3).
Remove the fuel tank shield mount bolt (2).
Remove the fuel tank shield (1).
Remove the right muffler, for automatic transmission-equipped vehicles only. Refer to Muffler Replacement - Left or Muffler Replacement - Right in Engine Exhaust.
Disconnect the fuel sender electrical connector.
Mark or identify each fuel pipe in order to aid in installing the pipes in their original positions.
Disconnect the auxiliary fuel return rear pipe (1) that connects the jet pump to the left tank and the auxiliary fuel feed rear pipe (2) that connects the left tank to the jet pump at the fuel sender. Refer to Quick Connect Fitting(s) Service (Plastic Collar) .
Cap the fuel pipes in order to prevent possible fuel system contamination.
Remove the right rear wheelhouse panel. Refer to Wheelhouse Panel Replacement in Body Rear End.
Remove the EVAP canister access cover.
Disconnect the FLVV hose (1) at the EVAP canister (2).
Disconnect the fuel pressure sensor electrical connector.
Disconnect the tank crossover hose (5).
Disconnect the EVAP pipe (2) quick connect fitting at the right fuel tank EVAP pipe (3).
Cap the EVAP pipe in order to prevent possible contamination.
Remove the fuel tank strap mount bolts (1, 2, 4)
Remove the fuel tank strap (3).
Remove the fuel tank.
Old Feb 12, 2007 | 02:13 AM
c5runs's Avatar
c5runs
i got everything disconnected, but i'm having a difficult time disconnecting the crossover tube. i can't see how it's connected so i'm not sure how to disconnect it. it seems that the only thing holding it in is the crossover tube, am i correct to assume this? any help would be great guys.
CorvetteTechInc: thank you for your post.
Old Feb 12, 2007 | 08:40 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
If you removed the shield then yes, the only thing now holding the tank in is the cross over tube.
Once the crossover tube is removed there is also a small evap tube above the crossover tube that connects the left and right tank (atleast there is on an FFS fuel system.
To Removing gas tank
