1st to 4th skip shift
Old Feb 13, 2007 | 01:29 AM
Tdoggindahouse's Avatar
Tdoggindahouse
Default 1st to 4th skip shift
Geez this is irritating! Bought a 2000 vert several months ago, didn't get to drive it much because of the SEVEN STRAIGHT WEEKS OF SNOW in my part of Colorado. Got it out the last few days, but this "more-annoying-than-a-barking-mother-in-law", supposedly gas saving feature is, well, irritating. So, several companies sell a "skip shift bypass." Looking for anyone who has experience with one of these. Any issues I need to know about? Hidden problems? Etc...thanks.
Old Feb 13, 2007 | 01:45 AM
nprsuit's Avatar
nprsuit
No problems, light on dash will still illuminate but allows you to shift into second. Had mine on my 00 vert for 3 years now without an issue.
Old Feb 13, 2007 | 01:55 AM
mdhmi's Avatar
mdhmi
You can have a tuner disable CAGS in your PCM (computer) or install a CAGS killer for around $50.
Having CAGS disabled was the first thing I did after purchasing my car. I felt is was just a horrible setup and frankly unsafe (pulling out in traffic and the stupid thing wants me to shift into 4th..).
Old Feb 13, 2007 | 01:57 AM
LF97C5Vette's Avatar
LF97C5Vette
Not really a fix for you - but it's something i noticed that i'm glad i saved $30 on... lol
I used to hit CAGS all the time, but now that I think about it - ever since my 4.10 gear swap, I don't think i've met the conditions for the CAGS since! So, a DTE Differential w/ 4.10 gears is a $1300 alternative to the resistor mod thingy... lol
Dan
Old Feb 13, 2007 | 02:55 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
If you drive your Vette in the GIRLY mode, you will experience the CAGS feature, a LOT. If you drive a little more aggressively you will never see it! I work on a military base (retired Navy) where the speed limit is 25 MPH MAX! I see/saw the CAGS feature more on a small military reservation more than any where else.
If your that concerned about CAGS, look for the 1st-4th light on the dash and when it illuminates, just mash the accelerator peddle a little bit harder (if you safely can) and you will never see CAGS!
I had it programmed out of my PCM via EFI Live. Guess what? It isn't a problem any longer, even on the Military base.
If you are forced to drive using a light accelerator pedal, your going to see CAGS unless you install the CAGS eliminator module or program it out of the PCM.
BC
Old Feb 13, 2007 | 03:09 AM
LKGRenegade22's Avatar
LKGRenegade22
I was thinking along the same lines of Bill. Quit babying the car and drive it! But on a more serious note, I very rarely ever experience it on my car due to my driving tendencies. I bought a skip shift and never installed it. It may still be laying around here somewhere...
Old Feb 13, 2007 | 05:06 AM
aubie97's Avatar
aubie97
I kept getting the light for the first couple of days, then just started to lean into her a bit harder.
Old Feb 13, 2007 | 09:00 AM
Frankie2blue's Avatar
Frankie2blue
It's a five minute fix. Throw the Cags bypass in and forget it. I had my car about an hour when i did mine. Then drive it however you feel like driving it.
Old Feb 13, 2007 | 11:06 AM
B-ras's Avatar
B-ras
The skip shift feature might not be an issue for a weekend toy, but it gets old quickly on a daily driver. The bypass is just a resistor. Install is easy, and I've never heard of anyone having a related problem.
Old Feb 13, 2007 | 12:11 PM
FRCTony's Avatar
FRCTony
I'm with Bill, you won't ever see the skip shift unless you are driving like Grandma.
Old Feb 13, 2007 | 01:48 PM
B-ras's Avatar
B-ras
OK, how about a left turn lane when you're the third car in line after a red light. You pull away slowly behind the traffic and move to drop it into second midway through the turn. But no! The computer puts it in fourth for you, so the car is lugging about 500rpm. Yes, you can fake the solenoid by going into the fourth gear gate then grabbing second, or you could have just tached it out a bit more in first.
The point is that there are lots of these situations in daily driving, and I don't want to have to re-learn my techniques or "work around" the electronic nanny. I accomplished this with a $20 part (which can actually be replicated for just a few $). I assure you I am no granny driver. If I wanted a computer to pick gears for me I'd have bought an auto.
Old Feb 13, 2007 | 03:56 PM
nonsuchpro's Avatar
nonsuchpro
My tuner removed the 1 to 4 shift when I had it tuned recently. He also turned the indicator light off in the computer.
Gone it is
Old Feb 13, 2007 | 05:41 PM
87SAM's Avatar
87SAM
I find that on the rare occasions the CAGs does come into play (as in the previously mentioned left turn at the light), that it does not necessarily force you into 4th. When you pull it out of 1st and feel the resistance at 2nd, you merely pause in that position for half a moment and it will then drop into 2nd.
Old Feb 13, 2007 | 07:09 PM
DirteeDave's Avatar
DirteeDave
Well put.
Old Feb 13, 2007 | 08:08 PM
dudleyd's Avatar
dudleyd
I agree, I get it once in a while when I'm in 5-10 mph stop and go but I never shift out of 1st under 3K anyway so I just ignor it.
Old Feb 13, 2007 | 09:37 PM
VetteBandit's Avatar
VetteBandit
Just bought and '02 with this lovely feature, noticed it on a test drive, but payed no attention to it and went to 2nd. I guess this means mine is disabled? I read the manual and it seems I should not be able to shift into 2nd when the light shows up. Can someone clarify for me: Does the 1 to 4 actually lock out 2 and 3 on a car that has it activated still? If not, what happens if you ignore it and shift into 2nd?
Thanks,
VetteBandit
Old Feb 13, 2007 | 09:53 PM
DirteeDave's Avatar
DirteeDave
Thanks,
VetteBandit
Sounds like you have the CAGS eliminator installed. Even though it allows you to shift into 2nd it doesn't eliminate the warning light.
To 1st to 4th skip shift
Old Feb 13, 2007 | 09:55 PM
PA_BLUE_C6's Avatar
PA_BLUE_C6
St. Jude Donor '05-'10-'12, '15
There is a soleniod that closes the gate going to second. This soleniod is pcm controlled. The software change and electrical resister both disable it.
Old Feb 13, 2007 | 10:11 PM
LoneStarFRC's Avatar
LoneStarFRC
Thanks,
VetteBandit
Yes it does lock them out and no, you can't ignore it. It will physically prevent you from shifting to either 2nd or 3rd.
I agree with DirteeDave. If you can shift normally into second or third when the light comes on, it means the CAGS system has been eliminated on your car using an easily obtainable plug in device (resistor).
On cars that can shift normally and have no light coming on, the CAGS system has been turned off in the ECM itself.
HTH,
Robert
Old Feb 13, 2007 | 10:19 PM
VetteBandit
Thanks for the info, Im glad I have the bypass - That seems like a bad idea on paper and in real life....what were they thinking?
-VetteBandit
