PCV Routing Question[SIZE="4"][/SIZE]
Old Feb 13, 2007 | 04:08 PM
zeevette's Avatar
zeevette
Default PCV Routing Question[SIZE="4"][/SIZE]
Probably been covered, but have a pretty specific idea in mind. I have a FAST90/LS2 TB on my ZO6, and recently added a oil catch can, and a Vararam intake. I've already eliminated my AIR system, and the Vararam has an opening designed for the hose of this system. Can I route my catch can output to this port, and then use the TB inlet as a port for the passenger side valve cover? The Vararam port is pre-MAF, BTW.
Old Feb 13, 2007 | 07:19 PM
zeevette's Avatar
zeevette
Nobody knows?
Old Apr 20, 2007 | 11:52 PM
VetteTech81's Avatar
VetteTech81
Ironicly I am having the same question... a well known tuner did the LS2 intake/tb on a customer Z06 and did not install a catch can the PCV system is connected on the manifold, pcv, and valley cover.. but they left the valve cover (intake side) fitting with nothing connected.. the car is tracked very hard and it was blowing oil (car has an accumsump on it) out the valve cover port on the passanger side.. the shop that did the work, could not tell me the correct way to setup and they have done many of these.. the did try to help by sending us a catch can, but the catch can is designed mainly for the vac. side of things..
But since it is able to spit out oil I do want to install one on the valve cover.. my only problem is the air coming into the system is unmetered by the mass air flow sensor.. granted it this only under vac conditions such as at idle or decel ect.. that is really makes a difference.. but i would like to see things routed correctly..
So we are either going to install the catch can and route it to the air intake duct somehow.. by installing a fitting or install it without a filter as it has one built in maybe.. not sure..
There is no factory setup for a LS6 with a LS2 intake..
I just wonder what this shop has been doing are they all being done like this without a hose or anything at the valve cover... and this is the only one as it's a first with an accusump?
Not sure..
Reason I have this car is the shop is out of state...
-=Rick
Old Apr 21, 2007 | 12:18 AM
thetorch's Avatar
thetorch
On the LS2, the clean air PCV tube connects to the bellows between the MAF and throttle body. I've asked this same question and never got a satisfactory answer. Most people vent the line to atmosphere, which I will not do.
This is what I plan on doing....I purchased the LS2 clean air tube from GM and plan on making an aluminum fitting to go in the air bridge or coupler between the TB and MAF so I'm getting metered air. Callaway has a fitting, vettenuts has one for his honker, that should work with the factory LS2 clean air tube.
Old Apr 21, 2007 | 03:01 PM
VetteTech81
The shop that did the work admited they normally leave the valve cover open to atmosphere without a filter or catch can ect...
When the customer first called them (the tuner that did the work) they said.. there should be a catch can there if you are tracking the car.. well what did you think he was doing with it with coil overs T1's big radiator accusump ect.. ??? So anyway my solution for now....
After talking with the other shop.. And what i was already thinking...
I installed a catch can from the valve cover and left the other port open to atmosphere, as there is a filter built into this catch can.. i want to see how much oil he is pushing out the vent/fresh air fitting at the passanger side head.. if it's minimal per each track session then, I would like to route the catch can to the air intake between the maf and tb...
I also want to install another catch can between the PCV and vacum port as well..
-=Rick
Old Apr 21, 2007 | 03:33 PM
vettenuts's Avatar
vettenuts
I just installed the fitting yesterday and am running it on the car pre-FAST installation.
I wouldn't attach the catch can to the intake in front of the MAF, any vapors would likely contaminate the wires. Also, not sure if you are asking if you can connect the PCV port to the valve cover. Got a diagram?
Here is the thread showing the parts I got:
Thread
Just went out and shot a photo of the aluminum part installed. I used some SMC bonding agent to set it in place and smooth it out in the coupler. It has a rubber cap on it since the original TB is still on the car until next week.
Old Apr 21, 2007 | 04:10 PM
thetorch's Avatar
thetorch
-=Rick
Or, you can run two catch cans like so:
Old Apr 21, 2007 | 05:22 PM
VetteTech81
Basically what we will be doing...
-=Rick
To PCV Routing Question[SIZE="4"][/SIZE]
