Power window stops 2" high
Old Feb 18, 2007 | 04:39 PM
stepuptata's Avatar
stepuptata
Default Power window stops 2" high
My window does not go down all the way. It stop 2" from the top of the door. ANy suggestions on this? Thanks for the help guys
Old Feb 18, 2007 | 06:31 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
The rubber boot that connects the door to the door frame has two wiring harnesses in it. While you hold the button in the down position, grab the rubber boot and shake it. Some times that works. If that doesnt work, your door control module may be going bad. Try slamming the door while you hold the buttons down.
BC
