Sqeaky shifter
Old Feb 22, 2007 | 04:34 PM
drbenne's Avatar
drbenne
Default Sqeaky shifter
My shifter began to squeak last event. If you are in neutral and move the shifter side to side it squeaks. Shifting otherwise fine. Someone told me to take off the center console and pull shifter out to lube the shifter attachment. Does anyone have some more info on how to do this?
Old Feb 22, 2007 | 05:42 PM
jbauch357's Avatar
jbauch357
Pull out the center console, remove the shifter and look down in the hole. There is a block that holds the shift shaft in place, add some lithium grease to where it slides and you should be fine.
That was a horrible description, I will look for a better write up...
Old Feb 22, 2007 | 08:14 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Here ya go! Once you remove all the plastic console trim, here is what you are in for. Its simple!
Remove te shifter handle:
You can LOCK the shifter in netural by inserting the rod in the linkage. Not necessary for the lubrication procedure.
Remove the FOUR bolts hat hold the shifter in place
Once the shifter is removed, you can add white grease to the shift rod inside the housing. Remember, it moves side to side AND forward to AFT.
Hope that helps.
BC
Old Feb 22, 2007 | 11:01 PM
jbauch357's Avatar
jbauch357
thanks bill, I was feeling a little guilty for giving such a half-a$$ explanation with no pics...:o
Old Feb 23, 2007 | 10:48 AM
B-ras's Avatar
B-ras
But you have people skills! (Office Space rulz)
Old Feb 25, 2007 | 10:15 AM
drbenne's Avatar
drbenne
BC
Thanks for the great pics. Really helps to know what you're getting into before I start tearing things apart.
Roy
Old Mar 9, 2007 | 01:31 PM
30PSI's Avatar
30PSI
Did this fix the problem? I was having this problem and tension between shift when it's warm. It would go in gear but it feels like I'm hitting something before it goes in only does this when warm. I thought it was clutch/slave cylinder got that replaced and problem still exist.
Old Mar 9, 2007 | 02:07 PM
Architect's Avatar
Architect
The (4) bolts holding the shifter in place come loose pretty easily. Remove those bolts and add some loc-tite.
Don't follow the instructions in the pictures above... that gouge you put in your shifter looks awful.
Old Mar 11, 2007 | 11:05 PM
30PSI's Avatar
30PSI
Just a little update on this I couldn't stand the noise and the tension between shift anymore so over the weekend I went over to autozone and bought me a bottle of lithium grease came home pulled the shifter off and sprayed the hell out off the linkage and the shifter itself(hell $5 wouldn't hurt right?)...guess what problem solved for $5!!! **** I wish I've done this before I had the new clutch and slave cylinder put in would have saved me over a grand...lesson learned
To Sqeaky shifter
