LS6 cam only pushrod length?
Old Feb 24, 2007 | 09:53 AM
500hp's Avatar
500hp
Default LS6 cam only pushrod length?
I have installed a TSP cam (Comp Cams) in my stock headed LS6/Z06.
I experimented with a couple of my stock pushrods instead of messing with my adjustable checker, and the valve tip pattern appears to be centered. I am able to tighten the rockers another 1/2 to 3/4 of a turn, from zero lash.
This sounds like it should be the correct length for my new pushrods... 7.400", correct?
Thanks.
Old Feb 24, 2007 | 02:04 PM
DJMRTS's Avatar
DJMRTS
The LS6 cam has a smaller base circle than the LS1 cam. I would suggest you go with longer 7.425" push rods to make up the difference. It will also help quiet up your valve train a bit.
Old Feb 24, 2007 | 07:00 PM
SLPRC5's Avatar
SLPRC5
My installer used Comp cams performance push rods 7.50 with the 2003 ZO6 cam and heads...using these same push rods with a Comp Cam install.
Old Feb 25, 2007 | 12:01 AM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
Should be 7.4s but many go w/ 7.425s for a little more preload... I use dthe 7.4s that came w/ my LGM kit and have no excessie valvetrain noise.... however I do have yella terra roller rockers.
Old Feb 25, 2007 | 01:43 AM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
To LS6 cam only pushrod length?
