Column Lock... new twist
Old Feb 26, 2007 | 02:41 PM
mitchcole's Avatar
mitchcole
Default Column Lock... new twist
I recently experienced the pull key, wait 10 sec show up on the DIC. Followed those instructions to get the service column lock.
The interesting thing is - the column isn't actually locked.
The fuel cuts off anyway - the first recall was completed by the previous owner.
So, I tow it to the dealer. They take a look at it and let me know that it qualifies for the latest recall to resolve the column locking problems. Unfortunately (for me) the column lock motor is what failed and that specific part is not included in the recall. So, for $495, they will replace the column lock motor, then install the recall to deactivate that brand new part.
Apparently - the motor has to be functional to complete the circuit.
I'm pretty calm about these things usually - but to spend $500 to replace a part that is then bypassed a wee bit over the top.
So - time to call GM. If that doesn't work, I think the CLB will resolve the problem because it simulates the column lock motor - which is exactly the part that doesn't work... I wonder if the dealer will let me work on my car in their parking lot?
Old Feb 26, 2007 | 03:07 PM
87SAM's Avatar
87SAM
$495 for a new motor just to disable it! You need to take maters into your own hands. Just hope it's not to late since you are already in fault mode.
Old Feb 26, 2007 | 03:16 PM
mitchcole's Avatar
mitchcole
I'm in fault mode. Everytime I start the car - the "service column lock" message shows up in the DIC. But - it's just electrical - the column isn't actually locked.... Crazy isn't it??!?
Old Feb 26, 2007 | 03:22 PM
dudleyd's Avatar
dudleyd
Get the CLB, anything the dealership does will result in the problem reappearing in the most inconvenient place, trust me on this one. I have a MN6 that has had all three recalls done to it. Since the last recall was performed in early 06 (removal of the locking plate) the junk relay in the harness-K has failed three times, So I finally followed CF member Cscokd (John Neese) advise and by passed the added relay in the passenger foot well, threw away the GM harness-K and built a CLB per John’s tutorial. Total cost was <$30 and about 2hr time. NO problems since.
Old Feb 26, 2007 | 03:23 PM
87SAM's Avatar
87SAM
Could be a faulty GM recall relay harness. The CLB may still work for you.
Old Feb 26, 2007 | 03:24 PM
dudleyd's Avatar
dudleyd
Ya, but can you go faster then 2mph?
Old Feb 26, 2007 | 03:30 PM
mitchcole's Avatar
mitchcole
nope
Old Feb 26, 2007 | 03:45 PM
dudleyd's Avatar
dudleyd
Can you hear the column lock motor when you cycle the ignition?
Old Feb 26, 2007 | 03:54 PM
mitchcole's Avatar
mitchcole
No. I believe the diagnosis from the dealer is correct.
Old Feb 26, 2007 | 04:59 PM
SilvaDragon's Avatar
SilvaDragon
This could very well be a failure where the column lock failed to
fully retract into its housing, so it didn't close the circuit that
indicates that the column is unlocked.
If this is the case, a CLB would fix your problem.
The only question that would linger is what state the column lock
is actually in...
Old Feb 26, 2007 | 07:16 PM
mitchcole's Avatar
mitchcole
I ordered the CLB. Should be here in a few days. I'm cautiously optomistic that this will fix the problem.. I've been reading through all these column lock issue posts and it's a bit confusing. If I had the first recall completed, there's an extra relay that needs to be bypassed? Is there any clear instructions on this?
Old Feb 26, 2007 | 07:22 PM
mrm1149's Avatar
mrm1149
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13
I'm sure someone is able to elaborate but essentially just follow the directions with the CLB in doing that, you'll be unplugging the GM K- Harness of which 3 of those didn't work for me. Got the CLB and not one glitch
Old Feb 26, 2007 | 07:42 PM
FRCTony's Avatar
FRCTony
We have a winner! I believe that chevy should pay for this since it's the fix that is most likely broken. If it is, the CLB won't fix it.
Best thing to do is remove the K harness or bypass the relay.
Please do not pay for a new column lock actuator, because it will never be used!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
I would not pay for any of this if I were you. I also would not take my car to the dealer unless I was desperate
Old Feb 26, 2007 | 07:49 PM
mitchcole's Avatar
mitchcole
No way in hell am I going to pay to put in a disabled part. Just to get that off the table.
But, I will milk them to pull off the locking plate... It's day one and the CLB won't be here for 3 days. That's plenty of time to be a PITA.
Old Feb 26, 2007 | 07:52 PM
FRCTony's Avatar
FRCTony
I hear ya. Just tell them to replace the harness K or at least the relay first. That should get the car running.
They probably have a drawer full of these relays.
I would'nt worry about removing the plate. They might hose up the steering column
Old Feb 26, 2007 | 08:47 PM
RedC5's Avatar
RedC5
Exact same situation for me this summer...had a nice flatbed ride. Had recall on auto 2 years ago then one day no motor action and resulting flatbed to dealer ending up with a $565 bill which I was pissed and paid.
Well after spending may calls to customer service, I got GM to refund my money. Tell then the root cause of the failure is the column lock motor even though it is not in recall and you should not have to pay for this since the recall was already performed and was not fixed correctly....keep bugging them! Good Luck!
Old Feb 26, 2007 | 08:57 PM
TEXHAWK0's Avatar
TEXHAWK0
With the Harness K harness installed, the actuator is still connected and you will hear the actuator cycle, even though the lockplate has been removed.
Unless GM changed the design of the relay in the harness, you can disconnect the actuator and the relay should still send the correct signal to the BCM to keep the fuel from being cut off. (the same way the aftermarket CLBs work)
At least one forum member connected the Harness K on his car a long time ago AND left the actuator disconnected and the system still functioned as intended.
Check out this link
http://forums.corvetteforum.com/show...ht=column+lock
I have read where several dealers have tried to charge the customer to replace the actuator, but you should not have to have a working actuator to get your car where you can drive it.
To Column Lock... new twist
Old Feb 27, 2007 | 12:24 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Yea,, the FLUX capacitor is also bad! You were most likely duped out of $500 bucks. Yea, bitch,,,bitch LOUDLY to GM Customer assistance!
Some things that you can do to help get your car back on the road are:
Charge the battery.
Clear ALL the DTC codes. The Column Lock is sensitive to set DTC's
It it still fails in the locked position after all the above, grab the wheel, insert the key in the ignition as you turn the ignition on and off and turn the wheel LEFT AND RIGHT.
I hope you get ALL your money back!
BC
Old Feb 28, 2007 | 08:36 PM
mitchcole's Avatar
mitchcole
UPDATE: GM has agreed to pay for the repair under some "good will" account.
I'm still going to look into installing the CLB when they're done...
Thanks for the support!
Old Feb 28, 2007 | 10:41 PM
Ol'55's Avatar
Ol'55
From: Southern New Jersey, The wet part at the bottom
St. Jude Donor '08-'09-'10
Viva la aftermarket CLB!
