The moisture is in the air flowing thru the throtle body.
Seems to me that to freeze it, it would take driving on cruise control on a completely flat surface where the throttle position doesn't have to change for hours and at 0 degrees
I think this is a non issue unless you're in a place like michigan or alaska
I was toying with the idea of adding a garden hose hook-up to the by-pass "tube" somehow to aid in flushing the block... Anyone have any thoughts on whether or not that would work?
Not necessarily due to the change in air pressure through the throttle body. It will happen quicker in more humid environments (like where I live )
Originally Posted by Dennis Wilson
The hose that goes to the top of the throttle body is NOT the one for the bypass, they are both on the bottom of the throttle body! one comes from the radiator & the other one exits the driver`s side of throttle body to a splitter that then goes to each head.
I was wondering how many posts I would have to read here before someone snapped to this.
What's the old saying about "A little bit of knowledge can be a dangerous thing"?
but come on... cant you just see the thread now???? my car was smoking horrible, then just stopped running right after doing the bypass mod. what happened?? oh... and my radiator is out of fluid
and its been around 36 here lately and very freakin humid. when the sun goes down ( most of the day ) it has been lingering right around freezing. add a cold air intake and that thing could look quickly like the frosty mug i keep in the fridge chilling
LONESTAR -
Thanks for catching that one and clarifying it. Like I said, if I do it, I want to do it right, that is why I asked questions before touching my car.
I'm still undecided though. If there isn't much benefit, why change the way GM designed the car.
