oil preasure?
Old Feb 26, 2007 | 11:47 PM
thetight's Avatar
thetight
Default oil preasure?
Well this is the first I have noticed today driving home from work oil preasure is at 80 and it's not cold out and the car was warmed up so I check the display and it reads 130 so I get out check the oil seems fine life is at 65% using royal purple 5w30 any thought on this
Old Feb 27, 2007 | 12:38 AM
Jim Taylor's Avatar
Jim Taylor
Lots of posts about this, including a sticky up top. The oil pressure sensor is bad. You need to replace it. Do a search and you'll find more postings about this than you care to read.
Old Feb 27, 2007 | 07:11 AM
65GGvert's Avatar
65GGvert
Search is your friend, search oil PRESSURE sender
Old Feb 27, 2007 | 07:20 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
It is your "OIL SENSER" you'll have to replace it soon! Look here on the forum: (all the info will apply to changing your's)
http://forums.corvetteforum.com/show....php?t=1588172
It is not a big deal in taking off the manifold to change it should only take a couple oh hours for a weekend wrencher to do. Check this out
http://www.ls1howto.com/index.php?article=5
Thanks, Matt
Old Feb 27, 2007 | 03:05 PM
berryj's Avatar
berryj
Here's my post on this issue w/ a nice link on how to replace it:
http://forums.corvetteforum.com/show...ght=change+oil
Many find that after they replace the oil pressure sensor that it can malfunction again as u will see on the above thread. This has led many to use some tubing to move the sensor next to the fuel rail to make it easier to replace in the future or to do the buick sensor mod listed in post #4 above. See the stick at the top of tech forum threads for more info on relocating the sensor.
I however as u will see by my post mentioned above, went w/ the factory replacement and torqued it to spec w/ a torque wrench to make sure there was no reason it should fail again. So far it's working, but for some other folks it didn't. Hope that helps u and let me know if u need any additional info.
Old Feb 28, 2007 | 12:24 AM
thetight's Avatar
thetight
How urgent is it to have this fixed? should I not drive it untill it's fixed or can it wait? I drive this car daily to work I really dont have time to fix it right now unless it's something that has to be done asap I will make the time
Old Feb 28, 2007 | 07:04 AM
madmatt9471
You don't have to sweat it right now! But I would do it when you have a oppurtunity too.
It's always best to be able to see what is going on in the engine VIA the oil pressure gauge.
Thanks,Matt
Old Feb 28, 2007 | 11:48 AM
berryj's Avatar
berryj
Thanks,Matt
To oil preasure?
