Cheap - Wire Feed Welders ??
Old Feb 27, 2007 | 05:13 PM
diyguy's Avatar
diyguy
Default Cheap - Wire Feed Welders ??
Anyone ever used one of these 'cheapy' welders for exhaust work?
Can't justify the cost of a $500+ mig welder, but for just a touch here and there on some very infrequent projects, just wondering if one of these 90 amp 110v units would do the job? Can use different kinds of wire feed, including mild steel and stainless wire as well. Some around the $200 range can use 75/25 gas with external tank... for mig welding.
I know the duty cycle is way low, but again, not in any hurry with it. Just an odd job here or there.
Opinions, Experience, Guesses? Anyone?
Old Feb 27, 2007 | 06:03 PM
brucemoose2's Avatar
brucemoose2
It'll work for exhaust.. but wire feed welders can be finicky and a piece of junk might not be worth it in the long run.
You might not be able to buy parts for some no-name welder you bought at Walmart or Harbor Freight or your favorite Chinese tool retailer. If you buy a Lincoln or something, you can easily find a dealer.
Obviously, if you buy a 110 welder, you can't weld very thick material... but if you only want to weld exhaust or autobody sheet metal, you should have no problems.
Old Feb 27, 2007 | 06:15 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
Bought a Lincoln at Home Depot and it works great I would buy the new Miller next time. Set ***** to wire size and thickness of material or something like that and go with it. I have stick welded for 30 years and bought this for thin stuff. Worked good so far for the 150 or less I paid. Miller is made in USA Lincoln Mexico
You could weld 1/4" steel or swap to aluminum wire.
Old Feb 27, 2007 | 06:24 PM
John Shiels
http://www.millerwelds.com/products/...c_140_autoset/
more than I thought
Old Feb 27, 2007 | 07:17 PM
KidCid's Avatar
KidCid
CI 7-8 Veteran
Originally Posted by John Shiels
Don't forget the cost of the tank. They work great though. I can't say much about the cheapie ones as I've never used them.
Old Feb 27, 2007 | 08:54 PM
hightest's Avatar
hightest
I've got one that I've been using for the last 2 years (lincoln).
It does excellent work, as long as you use it correctly and for the maximum guage of material that it's designed for (although I have successfully welded up to 1/2 inch material with it.. preheat, preheat).
I have done stainless with it as well with the MIG adapter kit, and you can do a very professional job as long as your settings are correct, and you push your puddle rather than pull it. Downhand welds are not very good with these units.
Old Feb 27, 2007 | 09:15 PM
John Shiels
tanks can't be much right?
Old Feb 28, 2007 | 06:19 AM
wrustywrench's Avatar
wrustywrench
I dont know wher eyou can buy one for 150, especially a lincoln.
I have a miller, have used a lincoln and bought a hobart. The hobart is a cleaper miller, but still a great machine.
I got mine for 400 with cart and regulators, you dont need a tank, you can use the flux wire, not as pretty, but will do just fine. I stop at 1/4 inch then break out the tig or stick welder.
DONT buy the cheapos, nothing but problems, spent the money and get a lincold or miller or hobart. get at least a 120 amp. They have some pretty nice ones, the new miller 110 volt is killer little machine.
I have a friend that bought one of the cheapos, it never feeds right, the damn thing always screws up the wire, ( smashes it and then sticks in the tip)...the rollers are not machined right and they crimp the wire no matter how you adjust it, I have the roller off to remachine the groove right ( today in fact) . he wishes he would have listened and bough the miller.
Old Feb 28, 2007 | 01:10 PM
white90conv's Avatar
white90conv
I have the Harbor Freight cheap welder. I bought it because it works on 120V and I was welding on a fence. I was able to do what I wanted but it was not as easy to use as my 240V AC stick welder. Took some getting used to. I expect it would be fine for exhaust work after some practice.
Old Feb 28, 2007 | 01:52 PM
Sleazy Rider's Avatar
Sleazy Rider
Veteran: Marine Corps
i sold my lincoln stick welder and got a cambell-hausfeld wire feed with the mig adapter. after relearning to weld using the wire feed, its not bad. and it uses 120v.
Old Feb 28, 2007 | 06:26 PM
gpracer1's Avatar
gpracer1
Years ago I debated getting a wire feed. I ended up with a Hobart TIG-mate. This way I can weld anything. Steel, Stainless, Aluminum, etc. Not the best for big projects like a 300 meter fence, but it does have the stick welder clamp too. Only drawback for some is 220/240V. But man I can weld 3/8 aluminum, even though it gets the torch hot. (after tripping 30 and 40 amp fuses, had to go 50 amp).
It was around $1200 8 years ago.
Old Mar 2, 2007 | 03:24 AM
Mikeceli's Avatar
Mikeceli
I bought a Harbor Freight(HF) 220V mig welder. It was on sale for $200. I have only used it twice and it seemed to work fine. BUT, I am NEW to mig welding and a poor judge of mig welders.
One of my shops had an Itiallian made HF unit, we bought in the early eighties. Worked fine(acording to the techs) till I left, in 1994.
To Cheap - Wire Feed Welders ??
