Knock Sensor problems
Old Mar 1, 2007 | 03:46 PM
PhreekZ's Avatar
PhreekZ
Cruising
Default Knock Sensor problems
OK... Long story short i changed the oil pressure sensor last night everything checked out fine after putting the intake manifold back on and what not. Went on a short drive oil pressure is great... now today i was driving it and went about 3 miles and the check engine light flips on. I run and get the code checked, and the code is for the knock sensors... both of them not just one. I'm almost positive i connected all back up before I put the manifold back on... any suggestions on what would cause this after i put the manifold back on? Could air leaking through the intake manifold cause this? I replaced all the gaskets and everything, but possibly something happened when reinstalling... I dunno..
This is on my 2003 C5
Old Mar 1, 2007 | 04:41 PM
PhreekZ's Avatar
PhreekZ
Cruising
bump
Old Mar 1, 2007 | 05:03 PM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
St. Jude Donor '06 & '12
Sounds like the plug on the back isnt hooked up. Or at least fully clipped in.
Old Mar 1, 2007 | 05:18 PM
PhreekZ's Avatar
PhreekZ
Cruising
Whats the best way to go about checking that? I cant fit my hand back there to feel for it really, and when my hand is in there i cant see to tell which plug it is anyway... any suggestions on how to get to that?
Old Mar 1, 2007 | 05:37 PM
jers98vet's Avatar
jers98vet
It's also possible that you pinched the knock sensor harness between the engine and manifold when you reinstalled the manifold.
Jer.
Old Mar 1, 2007 | 05:48 PM
PhreekZ's Avatar
PhreekZ
Cruising
ok if thats the case... when you are putting hte manifold back on where should that wire be going? Should i guide it to a certain area or what not
Old Mar 1, 2007 | 05:56 PM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
Straight back towards the firewall. You can throw some tape on it to hold it in place.
Old Mar 1, 2007 | 06:56 PM
PhreekZ's Avatar
PhreekZ
Cruising
I just pulled the intake manifold back off and that is what happened. It was caught right next to one of the manifold gaskets. It got crimped down pretty bad... Do i need to replace the wiring on it or will it be ok as long as I run it straight back?
To Knock Sensor problems
