Initial tune after supercharger install.....
Old Mar 3, 2007 | 08:23 AM
lodilobo's Avatar
lodilobo
Default Initial tune after supercharger install.....
I have a '99 FRC, that I installed a vortech supercharger on. I bought the supercharger used on ebay, so I did not get the superchips unit they supply. I do have a diablo predator for this car. Does anyone know if I can put an initial tune on this thing to it drive to the dyno so I can have them do a complete tune? The problem is that I have replaced the stock injectors with 42lb. injectors per the instructions. I haven't tried but I am sure the car won't run, unless the computer recognizes the change. I've called diablo and vortech....no help. I guess I could switch out the injectors to get the car there, but there must be a better way. Any suggestions, anyone?
Old Mar 3, 2007 | 09:06 AM
FRCTony's Avatar
FRCTony
You should fill out your profile...
Charlie Williams is offering mail order tunes here for $100.
This is what I would recommend. Send him your PCM, reinstall and drive.
http://forums.corvetteforum.com/show....php?t=1618197
Old Mar 3, 2007 | 03:12 PM
zeevette's Avatar
zeevette
When I did my H/C, I switched to 36.5# injectors, and the car ran just fine w/o a tune. You should be OK to drive it to get tuned.
Old Mar 3, 2007 | 03:50 PM
bennettrp's Avatar
bennettrp
St. Jude Donor '06-'07-'08-'09-'10,'13-'14,'19-'20-'21-'22
This is big time mod. PCM will not be able to adapt by itself, and don't touch it with the Predator.
I would pay for a dyno tune right away.
Good luck.
Old Mar 3, 2007 | 04:06 PM
STLKillerC5's Avatar
STLKillerC5
Why don't you just tow it there????
Old Mar 3, 2007 | 04:10 PM
7LitreC5's Avatar
7LitreC5
I would recommend putting your stock injectors in and using those until you get the car to the dyno. Just stay out of boost!
Old Mar 3, 2007 | 04:13 PM
Real Enthusiast's Avatar
Real Enthusiast
What he said.
It is common practice to drive to the dyno with stock injectors and do a quick 10 minute change just before dynoing. Just MAKE SURE YOU STAY OUT OF BOOST!!!
Old Mar 3, 2007 | 04:16 PM
onewheeldvl83's Avatar
onewheeldvl83
Tow it If it coast $500 for the tow it still will be a lot less then damaging anything on that motor. The stock PCM can only adapt up to a 20% afr error and you want to be running about 11.8-12.6 depending on the motor and boost. so with the injectors and the car not reconizing it the car will run way lean. If you put the stock injectors in it will be hard to stay out of boost you have a charger not a turbo. My opinion Tow it.
Old Mar 3, 2007 | 04:37 PM
hex's Avatar
hex
I agree with the last 5 guys. Better safe than sorry, and you need it properly tuned immediately.
Old Mar 3, 2007 | 04:43 PM
middlebrookgt's Avatar
middlebrookgt
i'm installing a Vortech supercharger on mine and plan to drive it to the tuner with the stock injectors.
Old Mar 4, 2007 | 12:00 AM
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
Yeah, like the other guys said, it will take you 30 minutes tops to replace your injectors and go back to stock. Without a reprogram EVERYTHING about your tune will be off since your computer will be opening and closing the new larger injectors as if they were smaller injectors, resulting in over-fueling and a car that likely won't run at all. But it will run just fine with stock injectors and your blower and no tune *at part throttle*.
It's not dangerous at all to drive it this way. As others have said, just go light on the throttle and you'll be fine. You'd have to try real hard to damage something -- some of the basic things that change in a FI tune include rescaling or changing some tables that would otherwise make the PCM throw a code if it saw more airflow than expected (e.g., you are starting to go into boost), putting you into reduced power mode.
Old Mar 4, 2007 | 02:03 AM
oahuyahoo's Avatar
oahuyahoo
My instructions specifically stated DO NOT DO ANYTHING until you have installed the program as per instructions and to the "T".
Old Mar 4, 2007 | 10:45 AM
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
Yep, that's good blanket statement advice -- but really, he'll be fine as long as he doesn't go into boost running off the old injectors. The MAF actually compensates more than people think for even light boost (1-2psi) but as I mentioned, before he can do any damage the PCM will see too much airflow and essentially shut the motor down by going into limp mode.
He could call A&A or ECS to confirm this if he wanted...
Old Mar 4, 2007 | 11:16 AM
97Rob's Avatar
97Rob
Old Mar 4, 2007 | 11:36 AM
ebilodeau84's Avatar
ebilodeau84
I ran into the same thing with my Vortech. I sent mine off to Charlie and had him do a base tune which was pretty close to perfect. All I had to do was fine tune it. It's worth the hundred bucks to send it to him then drive to the dyno. Just my .02.
Old Mar 4, 2007 | 12:48 PM
Corvette-Chris's Avatar
Corvette-Chris
St. Jude Donor '08
Rent a U-Haul car hauler, which is pretty cheap, and then tow it to get a good tune
Old Mar 22, 2007 | 11:24 AM
lodilobo's Avatar
lodilobo
I haven't been here to answer replies to my post since I originally posted it(computer problems). However, I did receive an e-mailed tune from diablosport and the car is running. Thanks to everyone here that had suggestions to the problem...I will be filling out my profile now that I am back on line.
To Initial tune after supercharger install.....
