rev limiter?
Old Mar 7, 2007 | 09:00 PM
Dean757's Avatar
Dean757
Default rev limiter?
I am enjoying my recently acquired 2003 anniversary edition roadster. I noticed that it revs to 6000 rpm very fast. So Far I have shifted the 6 speed by then or sooner. If I accidentally wind it tighter does it have a rev limiter?
Old Mar 7, 2007 | 09:06 PM
Tuner@Straightline's Avatar
Tuner@Straightline
6200rpm.
Old Mar 7, 2007 | 09:57 PM
Dean757's Avatar
Dean757
Default thanks I will shift at 5500 to 6000
Ok. Thanks
Old Mar 7, 2007 | 10:04 PM
Sleazy Rider's Avatar
Sleazy Rider
Veteran: Marine Corps
its not hard to bang the rev limiter when you are auto-x'ing as the engine pulls hard right up to there and you don't notice it. or too busy doing other things.
Old Mar 7, 2007 | 10:55 PM
jeanlucpicard's Avatar
jeanlucpicard
My limiter is set at 6,800rpm. If you're going to bump it you might as well BUMP IT!
Old Mar 8, 2007 | 06:19 PM
Dean757's Avatar
Dean757
Default Mods for the 6800?
Have you made mods to the engine or just adjusted the limiter. Since the warranty is expiring I do not want to over rev it.
Old Mar 8, 2007 | 07:12 PM
jeanlucpicard
See my sig - many mods to the engine and car in general.
Hi, my name is Jeanluc and yes, I am a modaholic.
A man's just got to have more horsepower.
Old Mar 8, 2007 | 10:39 PM
**IceMan**'s Avatar
**IceMan**
F a rev limiter. Tune that bad boy out.
Old Mar 9, 2007 | 12:30 AM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
Yes, but if you miss a shift it won't save you.
Old Mar 12, 2007 | 03:15 PM
Tuner@Straightline
Stock cams only pull to about 6200-6400 depending on if it has headers or not.
Old Mar 12, 2007 | 03:51 PM
chaase's Avatar
chaase
St. Jude Donor '12
Missing a shift is only a problem going down and picking the wrong gear. Going up you will bog (or if you never get it in a gear) the rev limiter will still step in
Old Mar 12, 2007 | 08:15 PM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
Your 224 cam's power drops off at right at 6000-6100. According to my dyno with the same cam. there's no real reason to have your rev limiter set at 6800. Well actually the only reason would be not to make an additional shift in the quarter mile.
Old Mar 12, 2007 | 09:13 PM
MAR2001's Avatar
MAR2001
Phils_C5... Quick note on your vids - just awesome!
Old Mar 13, 2007 | 09:43 AM
brentg454's Avatar
brentg454
I treat my rev limiter like my wife - I kiss it at least twice a day...
To rev limiter?
