Knee deep into my Head / Cam install...
Really outstanding work, I've been reading every post, thinking I might try this myself as well.
Show us some video once you have it off jacks and on the driveway or something.
You da man!!!! You gonna get it tuned on a dyno? I would like to see the numbers.
Fired her up today, and the oil pressure came right up to the upper 50's. Everything seemed kosher, so I took it for a spin around the block (ok, a little farther).
My impressions thus far:
It doesn't idle quite as well as I thought. After any trip up in rpm's, it has to hunt for an idle. The first time I backed it out of the driveway, it nearly died.
It seemed to get a little better as I drove around, though. Oil pressure at 210 degrees was around 34-36 at idle. At 1,700 cruising, it was around 47. I think I'm set there. I got one error code for a mis-fire early on, but since then, no codes came up. I wish I could say I could feel gobs of extra power, but I can't. I just don't have the ***** to get on it much at all. I gave it about 1/8 throttle to 3k once or twice, but I just couldn't risk all that hard work for a joyride.
The exhaust sounds great! I really wanted to keep her a sleeper(ish), and the Z06 Titanium catback sounds incredibly tame at idle and under light loads. The couple of times I got on it a bit told me it's going to sound awesome under full throttle. It's the best of both worlds if you aren't out to get attention all the time. I'll get a new video up later for the guy who asked... Thanks for all the help guys. You have given me hope and courage to see this thing through! I have an appointment for a tune on 4/23. I'll be sure to post the graph.
Vettenuts, I'll be dumping my old oil filter soon, and I'll let you know if I find anything interesting...
If you listen, you can hear a bird chirping loudly, so it gives you an idea of how overstated the sound is. I noticed more of a lope after it warmed up, and the idle dropped a bit. I believe it's idling around 600 when warm. This exhaust is going to sound absolutely sweet taching up and under load, though. I still haven't gotten on it much (and don't plan to until the tune), but the little bit I have given it sounds awesome, without being obnoxious!
Don't give me any crap if you notice the exhaust leak by the driver's side... I will get to it soon enough.
P.S. The valve train noise is amazing. There's not much more of a sewing machine sound than it was in stock form.
