Knee deep into my Head / Cam install...
Old Mar 21, 2007 | 11:24 AM
  #61
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
^ There you go... it sucks but you'll have to pull the rack, the radiator, the water pump, and the crank pulley, then remove the timing cover to get at it.
Or you might could remove the oil pan from below... drop it down and get at the o-ring.
Old Mar 21, 2007 | 11:29 AM
  #62
kilrb's Avatar
kilrb
Oh wouldn't that just be a freaking dream come true!!!
Old Mar 21, 2007 | 12:43 PM
  #63
Chuck01's Avatar
Chuck01
Default Props
Kilrb, I must give you props for taken on such a Job. I wish I had the ***** to tackle something like a H/C install. Job luck and hope all finishes well.
Old Mar 21, 2007 | 01:03 PM
  #64
Cobra4B's Avatar
Cobra4B
Hmmm go over to www.corvettemechanic.com and ask C4C5Specialist if you can drop the pan down enough. You may be able to get the pan loose, drop it enough to get at the o-ring.
However my buddy Joe just ripped back into it... having done it once it didn't take him long at all to get back in it.
Old Mar 21, 2007 | 02:09 PM
  #65
kilrb's Avatar
kilrb
Yeah, I was thinking I could tear it apart in less than four hours now that I know what I'm doing.
Old Mar 23, 2007 | 10:16 AM
  #66
jo8243's Avatar
jo8243
Hey kilrb... how much time do you think you have invested so far (before you start tearing into it again)?
Old Mar 23, 2007 | 10:48 AM
  #67
kilrb's Avatar
kilrb
It's embarrassing to admit it, but... I would say I have a good 60 hours in it. (remember, I also did a header install, which added some time, and I spent two or three hours cleaning my pistons) A significant chunk of the time came from running to Napa for tools/parts, and as you know, I had plenty of "oopses". I really took my time though, and I did a lot of it in three hour chunks, which isn't as efficient as bigger spans of time (cleanup takes a little time). I would guess that if you are a green mechanic, you can use the long end of LS1howto.com's time estimates to get an idea of how long each part will take. But if you really take your time and read the instructions several times, it can stretch beyond those numbers. Obviously my install did.
Having done this once, however, I would think I could do it again well within the time estimates on howto.com. I'm going to be tearing back into the front end again tonight. I'll let you know how much time I knock off from experience. I won't be rushing, but I'm sure it won't take as long... Don't let this project scare you; other than your time/money, there's nothing that complicated about it.
Old Mar 23, 2007 | 11:12 AM
  #68
jo8243's Avatar
jo8243
Thanks for the numbers. I think it would take me a long time as well. No need to be embarrased if the end result turns out good.
Old Mar 23, 2007 | 12:13 PM
  #69
jo8243's Avatar
jo8243
Another question... when you fired it up earlier, how clean did it run with the stock tune? Did it run long enough to warm up or did have to shut it down pretty quick?
Old Mar 23, 2007 | 12:17 PM
  #70
kilrb's Avatar
kilrb
Did you see my video? If not, it's several posts back, and you can hear it start up for the very first time, and idle for about a minute. I left it idling for 2 or 3 more minutes after that, and I was absolutely amazed at how clean it idled. I'm not going to go out and beat on it without a tune, but it would defnitely be driveable without a tune. I really expected it to lope off of the jack stands, but it idled great.
Old Mar 23, 2007 | 12:33 PM
  #71
jo8243's Avatar
jo8243
Oh yeah, sorry, I'm looking at this from work and videos and pics and stuff get blocked. I'll check it out from home tonight.
Old Mar 24, 2007 | 02:18 AM
  #72
kilrb's Avatar
kilrb
Default Looks like the O-ring
Well, I got her apart, and didn't have to take out the radiator. I opened up the timing cover, and lo and behold, the O-ring was fried. As you can see, the O-ring is actually missing a nice chunk, which makes me wonder how worried I should be about it floating through my system... I suppose it could have been torn into several tiny peices, or there could be one big chunk. Is there anything I should do to mitigate it? I also have included a shot of the new O-ring as it sat just before I tightened the pick up tube. It went in smoothly while sitting on the snout this time. Does it look straight to you guys?
Old Mar 24, 2007 | 06:17 AM
  #73
GotMoJo's Avatar
GotMoJo
That looks good!
Oh and clean under your fingernails.
Old Mar 24, 2007 | 07:35 AM
  #74
vettenuts's Avatar
vettenuts
PM sent
Old Mar 24, 2007 | 09:53 AM
  #75
94legaleagle's Avatar
94legaleagle
Old O-ring SUCKS!!! - I think you found your problem!
New O-ring install looks GOOD
Old Mar 24, 2007 | 10:01 AM
  #76
kilrb's Avatar
kilrb
That picture shows all the farther the pickup tube wanted to go by hand. Should it have gone farther up? I bolted it in from where it sat in the picture while trying to keep it as level as possible...
Old Mar 24, 2007 | 02:19 PM
  #77
vettenuts's Avatar
vettenuts
It looks parallel and may be OK, but it should have slid in all the way so you just had to put in the bolt.
To Knee deep into my Head / Cam install...
Old Mar 24, 2007 | 02:43 PM
  #78
FactoryRaceCar's Avatar
FactoryRaceCar
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12
Originally Posted by vettenuts
We're all here to electronically help, especially those of us stuck in winter hibernation mode
Old Mar 24, 2007 | 02:46 PM
  #79
Brad@RevXtremeAutoSports's Avatar
What i see as important is you are overcoming the roadblocks and obstacles and staying with it. A lot of people would have given up but you have not, I admire your determination.
Looking forward to your completion.
Best of luck to you.
Brad
Old Mar 24, 2007 | 02:49 PM
  #80
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
..And would have if it was slathered up with assembly lube..
