Does this cam look dot to dot???
Old Mar 10, 2007 | 02:29 PM
kilrb's Avatar
kilrb
Default Does this cam look dot to dot???
Just for safety's sake, I thought I'd post a shot of my cam install to make sure I'm dot-to-dot. Every time I try to get the dots straight up and down, I miss it by a hair on either side. From what I have read, if you are off, it's fairly noticeable, and from what I see in the picture, it looks like the dots should line up straight if I could get the crank to stop where I want it to... Anyone?
Old Mar 10, 2007 | 02:38 PM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
Yes, you are fine, continue..
Old Mar 10, 2007 | 03:00 PM
90droptopp's Avatar
90droptopp
From: Murrieta Ca..... America, fun while it lasted
Old Mar 10, 2007 | 03:03 PM
Corvette-Chris's Avatar
Corvette-Chris
St. Jude Donor '08
That is fine !
Chris
Old Mar 10, 2007 | 04:54 PM
Tony @ MPH's Avatar
Tony @ MPH
Supporting Vendor
Yeah, that's as close as you're gonna get. Because of the teeth on the gears, if you're off... you'll know it -- it will be wayyyy off.
Old Mar 10, 2007 | 04:57 PM
bennettrp's Avatar
bennettrp
St. Jude Donor '06-'07-'08-'09-'10,'13-'14,'19-'20-'21-'22
My buddies and I had an arguement over this when i did my h/c. So what we did was take a straight edge (like a ruler) and line it up thru the cam center and cam dot. If things were lined up, the straight edge had to then run thru the crank dot.
Surprisingly, the first time, it did not. So it was well worth the effort.
Old Mar 10, 2007 | 10:40 PM
illmac77's Avatar
illmac77
CI 7-8 Veteran
CI 8 Car Show Winner
St. Jude Donor '07
Looks just like when i put in my H/C 5k miles ago.
To Does this cam look dot to dot???
