Denso Plugs
Old Mar 11, 2007 | 10:36 AM
Funn One's Avatar
Funn One
Default Denso Plugs
Hey guys getting ready to put Denso Plugs (5325) in today the gap apears to be around .045 from Denso will this be O.K.Thanks!!!!!
P.S. This is what i got off there web site.
Q. Do I need to set the gap?
A. Generally, no. The DENSO Iridium Power plug comes pre-set with a protective sleeve over the firing end, to protect the gap from accidental alteration. DENSO Iridium Power’s ultra-efficient firing power compensates for normally recommended gap settings that are smaller than the pre-set value. In the cases of vehicle modifications (nitrous, turbo-chargers, super-chargers, high power ignition systems, etc.), some adjustments may be desired. Or, if you prefer to remain consistent with factory specifications, you may adjust. However, please be careful not to place any stress on the fine center electrode during adjustment. You could accidentally break off the very hard, and therefore brittle, tip.
Old Mar 11, 2007 | 11:09 AM
vettenuts's Avatar
vettenuts
I didn't touch mine and was advised not to. Car runs great. Denso Iridiums were recommended by Katech.
Old Mar 11, 2007 | 12:00 PM
Funn One's Avatar
Funn One
Thanks!!!
To Denso Plugs
