Removing Intake Manifold
Old Mar 14, 2007 | 04:32 AM
Choreo's Avatar
Choreo
Default Removing Intake Manifold
Is there a thread with pics on how to do this on a 2001 LS1?
Old Mar 14, 2007 | 05:42 AM
vettenuts's Avatar
vettenuts
This should give you most everything you need
LS1HowTo
Old Mar 14, 2007 | 09:06 AM
berryj's Avatar
berryj
Here u go :
http://forums.corvetteforum.com/show...ght=change+oil
Old Mar 14, 2007 | 09:13 AM
SteveDoten's Avatar
SteveDoten
Cruise-In VII Veteran
pull the vac. hose off the brake booster and remove w/ manifold(it's easier)
pay close attention to the map sensor plug, hvac vac source and knock sensor harness during removal and installation
the 2 rear bolts will NOT be removed or installed unless the intake is in place first
To Removing Intake Manifold
