Weird electrical problem occuring
Old Mar 15, 2007 | 07:50 PM
Double Aught's Avatar
Double Aught
Default Weird electrical problem occuring
Car has been running like a top. I go to the vets office, come back out, turn key to on, let gauges cycle, lower my windows then start the car. Car started up normally and then every warning message came up on the DIC. The only gauges that worked were the voltmeter, speedo and tach. Pulled out and drove it home, car ran normally, no reduced engine power. Gauges came back on for about 30 seconds, then went dead again. Got home, raised the driver's window, but the passenger window will not go up using either switch. I have just disconnected the battery, but don't think it will do anything. Does anyone have an idea what might be the problem or where on the car I can look to start a diagnosis?
Old Mar 15, 2007 | 11:03 PM
Corvette-Dan's Avatar
Corvette-Dan
I am a rookie to the Vette world but I have heard alot about funky electrical problems that come and go. From what I heard it could be one of the chassis grounds located on the car. I also heard that if the battery cracks it will leak to the main chassis ground which is right below the battery tray. My problem here is that I have heard that what is below the battery is one of a few things, and I'm not sure what to believe. I've heard that it is the main chassis ground, the BCM, ECM, or an electrical junction. Whatever is below that battery, if it gets battery acid on it, I'm sure it is not a good thing. If the car does have several chassis grounds as I'm inclined to believe, dirt and moisture from bad weather driving could possibly contribute to intermittent maladies. Since the cars body is fiberglass and plastic it would make sense that it has unique grounding points on it compared to a normal car.
Old Mar 16, 2007 | 10:13 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Double Aught
Your problem sounds like it could be Body Control Module (BCM) related.
The BCM is a big silver box next to the fuse box in the passengers foot well behind the toe board and it is VERY sensitive to moisture/corrosion.
C5's are known to experience a clogged HVAC air box drain which can cause the AC Condensation to flood back into the passengers foot well and cause havoc with the gage cluster!! Been there!
My 98 had it BAD! check the BCM, the carpet and the jute carpet underlayment for moisture. If there wet, let me know!
There are also leaks that can occur from other passenger side areas. Water in the passengers foot well is NOT C5 friendly!
As for the door issue, grab a hold of the rubber accordion tube that connects the door to the door frame, feel for the TWO wiring harnesses inside the tube. grab them and shake them while you press the up or down buttons for the window.
BC
Old Mar 16, 2007 | 11:12 AM
Double Aught
Originally Posted by Bill Curlee
Double Aught
BC
Thanks BC. I was going to look at the BCM and now I know about the window harness check. I'll post later today about both.
Old Mar 16, 2007 | 06:15 PM
Double Aught
Well I did the harness trick and it worked. The DRL's are still non-functional. Thanks for the suggestion.
Old Mar 16, 2007 | 09:49 PM
jmzvet's Avatar
jmzvet
Bob lives in Hell (So. Arizona) so I doubt there is any moisture within a hundred miles of his Vette .
Old Mar 16, 2007 | 10:25 PM
Double Aught
Why thank you for your valuable contribution to my thread.
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Bob lives in Hell
Ahhhh yes,,,but,,,,I bet people in hell need AC! If you run the AC, you will get condenstaion in the air box and on the AC equipment under the dash. If it condensates, it will FIND IT WAY to he BCM (MURPHYS LAW SAYS SO!!)
If you had the AC on, it's a good bet that it could have gotten damp.
BC
Old Mar 16, 2007 | 10:36 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Seeing how were on a roll, I'll take a lok at that problem too!
BC
Old Mar 16, 2007 | 10:48 PM
Dave68's Avatar
Dave68
It looks like you conveniently forgot to tell everyone the story about the jug of moonshine that you bought from these guys:
Apparently, the not-tight-enough jug spilled all over the passenger side footwell, back a few weeks ago.................
Old Mar 16, 2007 | 11:18 PM
Double Aught
BTW Daaave, here in AZ, I can buy as many AK47 rifles as I can and I know one will have your name on it. hehehehehehe.
Old Mar 16, 2007 | 11:53 PM
Dave68's Avatar
Dave68
Bob, you live in Arizona, NOT Texas!
Old Mar 17, 2007 | 12:52 AM
Double Aught
Umm, Dave, you should see my safe. And the guns under my spare bed.
Old Mar 17, 2007 | 12:58 AM
jmzvet's Avatar
jmzvet
Don't forget who installed your rear diff for $0 and who bought you dinner after you helped paint my house .
Old Mar 17, 2007 | 01:21 AM
Dave68's Avatar
Dave68
How could you possibly charge a guy who has a safe full of AK47s?
Old Mar 17, 2007 | 10:03 AM
gpracer1's Avatar
gpracer1
Arizona , gotta love it.
Old Mar 17, 2007 | 10:45 AM
Double Aught
Old Mar 18, 2007 | 06:32 PM
PITTSBURGH VETTE's Avatar
PITTSBURGH VETTE
8th Gear
Default same
i'm haveing the same issues. car runs fine then i will get a high voltage reading and gages cluster will go nuts.DEAD is this BCM costly to replace or just needs cleaned or what??
thanks
Old Mar 18, 2007 | 10:36 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Why would you think it would be a BCM issue?? What DTC'c are you seeing???
BC
To Weird electrical problem occuring
