Wheel Weight Placement vrs Rhythmic Vibrations
Old Mar 16, 2007 | 03:56 PM
Burgie's Avatar
Burgie
Default Wheel Weight Placement vrs Rhythmic Vibrations
Curious as to an issue with Rhythmic Vibrations:
Those with the vibrations are your weights attached to the leading edges of the wheel both inside and out or inside the bell where they are not visible?
Old Mar 16, 2007 | 09:15 PM
Burgie's Avatar
Burgie
ttt
Old Mar 17, 2007 | 02:59 PM
Burgie's Avatar
Burgie
no one with a vibration issue that can't tell if the weights are visible on the face of the wheel or not?
Old Mar 17, 2007 | 03:23 PM
Carol & Lee's Avatar
Carol & Lee
98 coupe A4 with polished thin spokes and my weights are on the inside of the wheel (not inside the tire) just as close to the center of the rim as possible and I am running run flats and have no vibration at any speed. find the best tire machine in your area to have yours balanced. Make sure the weights don't hit the brake caliper
Old Mar 17, 2007 | 04:42 PM
Burgie's Avatar
Burgie
Thank
Steve
Old Mar 17, 2007 | 05:43 PM
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
My weights are also in the center of the wheel but I DO have the rhythmic vibration. But I also have a known bad LR tire that was crushed by an inept tire mechanic installing em (original EMTs) unto my new thin spokes. So all this happened at once, new wheels = vibration. I found the bad tire by getting them road force balanced. The tire showed 36 lbs of force and the whole wheel/tire assy showed 41lbs...
Hope that helps ya somehow...
Old Mar 17, 2007 | 06:17 PM
Burgie's Avatar
Burgie
If it is a Goodyear- they will replace under six months and 2/32 wear. 36 is quite high from what I've had.
Now when you say center, am I to understand the weights are laid in the measured center (wheel edge to wheel edge) and none are applied to the inside or outside rim edge?
Old Mar 17, 2007 | 06:26 PM
AU N EGL's Avatar
AU N EGL
That may be the problem. wts should be placed on the inside of the rim where they are needed.
On my wheels some of the wts are closer to the spokes, some are closer to the inner edge to get a balanced wheel/ tire combination
I also put HVAC alumium tape over the stick on wts to assure they stay in place.
No virations here
Old Mar 17, 2007 | 06:33 PM
SouthernSon's Avatar
SouthernSon
The last two sets of tires that I have mounted, toyos and Firestone WOs, I went with static (one weight in center inside of wheel) as opposed to dynamic balancing (a weight on the inside lip as well as outside lip). Of course, the balancing of each type is on the same machine, just programmed differently. I believe I like the static mode better so far.
Old Mar 17, 2007 | 06:49 PM
Burgie's Avatar
Burgie
No virations here
That is how mine are currently set up and suspect to what is causing a rhythmic vibration-wheels are Z06 Motorsports OE Creations. If I understand the other writer, the weights should follow a middle line of the wheel (rear 5 1/4") in from the inside on the rears and 4 1/4" in on the fronts-make sense?
Old Mar 17, 2007 | 07:12 PM
AU N EGL's Avatar
AU N EGL
Check those OE Creation wheels. they may not be as balanced as they should be. and not correctable with weights.
Wts should go where they are needed, not on the center line.
The place the wt is put on changes with the new tires too. Not all the same tires are equal wt.
I normally have 8 wheels mounted and ballanced at a time. The wts dont seem to go into the same places with each mounting.
Old Mar 17, 2007 | 08:06 PM
Burgie's Avatar
Burgie
They have been road forced balanced at least four times. Each time there is some minor change as expected. Vibration improves a little or gets worse, Either case, changing back to OEM polished 01s next week as I feel its the steel wheels themselves. Hope Im right.
Old Mar 17, 2007 | 08:59 PM
AU N EGL's Avatar
AU N EGL
Good Luck - Hope you can feel a difference.
Old Mar 18, 2007 | 12:32 AM
tstar's Avatar
tstar
I don't know how old the tires are, they were on it when I bough it. And yes, measured center of the wheel from edge to edge.
My vibrations start @ 70ish MPH...
I hope it's those wheels or a wheel that can easily be returned and replaced, I know you've been batteling this for a long time!
Old Mar 18, 2007 | 07:57 AM
AU N EGL's Avatar
AU N EGL
I use to have a vibration that started at 82 mph. Turned out my alignement was slightly off.
What do your tires look like ??
Old Mar 18, 2007 | 12:23 PM
Burgie's Avatar
Burgie
My tires are new (five months old) and a right rear wheel was replaced as the Road force showed the assembly at 19. I've had the alignment and basically waiting or vasilating to try a center balance or just wait and do a remount on factory wheels.
Old Mar 19, 2007 | 01:57 AM
tstar's Avatar
tstar
They look brand new, I haven't measured but I'd say 9/32s if anything... I've been looking on here for a good used one but no luck so far.
Old Mar 19, 2007 | 08:09 AM
AU N EGL's Avatar
AU N EGL
I would do a remount. Again I feel stick on wts should be placed were needed on the rim, not just on the center line.
Rember to clean the inside of the rim with spray brake cleaner. If you have stick on wts take them off prior to remount and clean the rim.
Tire weights are not evenly distributed around the whole tire. It is close but not exact.
Good Luck Guys
To Wheel Weight Placement vrs Rhythmic Vibrations
