Wheel question.
Old Mar 20, 2007 | 09:17 PM
radiowaves88's Avatar
radiowaves88
Default Wheel question.
Hello. I have a 2002 convertible. I would like to change to chrome Z06 style wheels. My question is, can I go one inch wider in the front and rear ( 8.5 to 9.5 front, and 9.5 to 10.5 rear ) and still use my original tires? The tires are in great shape, so I would like to keep them. Thanks for your help, Al.
Old Mar 21, 2007 | 12:36 AM
LT1driver's Avatar
LT1driver
yes, I have 11" on back of my ZO6, 10.5 is stock, no problems
Old Mar 21, 2007 | 12:46 AM
wamara's Avatar
wamara
Cruise-In II Veteran
Al, just to clarify, you have the GY runflats? While the wider Z06 wheels still fall within this tires' sizing parameters, I don't think it's the best sizing application. Be that as it may, if you are bound and determined, you can do it.
Old Mar 21, 2007 | 08:51 AM
rws.1's Avatar
rws.1
front tires are 245/45/17 the recommended spec is 7.5-9.0 inches wheel width
rear tires are 275/40/18 the recommended spec is 9-11 inches wheel width
The tires will have their sidewalls stretched outward... it is a European look...
It can be done, but looks a bit odd and the stretching opens up the bead area a bit and leaves the rim unprotected from curbs even in tires that have built in curb protectors.
here is a photo from a car show that shows stretched tires.. in this shot the rears are more noticable because of the angle.. you can see how the outside lip of the wheel is opened up and exposed...
Old Mar 21, 2007 | 10:26 AM
wamara's Avatar
wamara
[QUOTE=rws.1;1559459480]front tires are 245/45/17 the recommended spec is 7.5-9.0 inches wheel width
Per TireRack's published specs, fronts will fit 7-9.5" wide rim.
Regardless, I agree with you (as I said in my reply) - not a good idea.
To Wheel question.
