Wiper Position/Motor Problem
Old Mar 26, 2007 | 11:03 AM
FrogmanDave's Avatar
FrogmanDave
Default Wiper Position/Motor Problem
Last week my car sat outside all night during a very heavy rain storm (it has always been garaged so this is the first time). After the storm my wipers now function on their own. They will pop up and do a couple of intermittent wipes and sometimes go down or stay in the up position. They will be in the up position when I shut the car off and if I leave it sit for awhile and turn the key on, they will go down, but eventually pop back up. I turned the key off when they were in the down position and took the negative batte3ry off to maybe reset the BCM but that didn't fix the problem. I think it has something to do with moisture and the encoder that tells the motor the position of the wipers. Anybody else had the same problem?
Thanks,
Dave
Old Mar 26, 2007 | 11:18 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Dave
The most probable cause for the wiper malfunction is the wiper control module is / was submerged under water. The module sits in a well. The well is located on the drivers side of the windshield cowl. There are THREE utter type drains that keep the well dry but they often get clogged with gook and require cleaning.
There is a space between the fender and the power brake booster that you can reach your hand into and you will be able to feel the udders. There normally soft and pliable but if there clogged they will be hard and full of nasty trash.
You can try to milk out the trash or you can pop them out. They pop out and install easily. Once there out, I strongly recommend flushing out the well with a water hose prior to reinserting the utters
If your lucky the module will dry out on its own and work properly. If you not, it will require removal and maybe even replacement.
Try the cleaning and self drying method first.
Bill
Old Mar 27, 2007 | 08:38 AM
FrogmanDave
Thanks for the info Bill. It seems that this problem is somewaht common. I checked the bladders last night and they were all clean of debris. Also the water bucket was completely dry. I went ahead and took out the entire wiper assembly and blasted it with a hair dryer for about an hour. I re-installed the assembly and everything worked fine. Thanks for the help!
Dave
Old Apr 8, 2007 | 11:53 PM
Cajun @ Edgyvette's Avatar
0Cajun @ Edgyvette
Former Vendor
St. Jude Donor '07-'08-'09-'10-'11-'12'-'13-'14-'15
Are there any schematics to show where this module is? I am having the same issues. Thanks
Cajun
Old Apr 9, 2007 | 12:41 AM
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
The module is attached directly to the underside of the wiper motor itself... well thought out design!
Old Apr 15, 2007 | 04:30 PM
imflyinbiya's Avatar
imflyinbiya
I am having the same issue, but dont know where to look for the module. I want to dry it out, and or replace....
Can anybody point me in the right place?
Old Apr 15, 2007 | 10:24 PM
nitrojunky's Avatar
nitrojunky
Directly above the driver's side 'udders' in the cowl; the black plastic under the wiper motor.
My experience is post 9
Old Apr 16, 2007 | 01:13 AM
tstar's Avatar
tstar
Excellent post BTW, I used it installing my new motor. After adjusting the top cam, I realised that it was the problem all the time and NOT the motor!
Go figure...
Old Apr 16, 2007 | 10:50 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Here is a picture of the udders (the hard way)~
The contro; module is in this well under the motor.
Here is where you can reach the udders:
Old Apr 17, 2007 | 01:37 AM
imflyinbiya
Thank you for the pictures! Helped a ton...
Old Apr 23, 2007 | 12:56 AM
imflyinbiya
So I took out the moter/control module today and inspected it (new one on order). I cleaned it, etc and reinstalled. It seems that this entire time the computer is telling it to opp in reverse???
Does anyone know how to reset this, etc? Maybe it will save me the expense...
Thanks!
Old Apr 23, 2007 | 10:56 AM
Bfail's Avatar
Bfail
Originally Posted by Bill Curlee
Dave
Bill
I had this exact problem about 3 months ago. It is the wiper motor, not the module. I got my module fixed and they continued to work on there own. So, just get the motor fixed and you should be alright
To Wiper Position/Motor Problem
