Old Mar 2, 2015, 08:10 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Engine and Powertrain
Print Wikipost
Katech Coil Relocation Kit
Old Mar 27, 2007 | 12:03 PM
John Micheal Henry's Avatar
John Micheal Henry
Default Katech Coil Relocation Kit
Will this kit work with stock type valve covers?Thanks in advance,J.H.
Old Mar 27, 2007 | 12:29 PM
Mike94ZLT1's Avatar
Mike94ZLT1
I'm sure it would, why would you want to use it with the ugly stock valvecovers though?
Old Mar 27, 2007 | 12:35 PM
John Micheal Henry
Not going to.I'm going to powder coated CHEV. PERFORMANCE valve covers.PRETTY!!
Old Mar 27, 2007 | 02:12 PM
KBlanke's Avatar
KBlanke
According to Katech it will work with their valve covers only. I have a set of C5-R covers that I wanted to use their kit with, they said that I would need to drill some holes and then thread them for that kit to work.
Old Mar 27, 2007 | 02:20 PM
John Micheal Henry
Thanks that is what I've heard.Do anybody know of a kit to relocate the coil packs above the valve covers using stock like covers.Thanks J.H.
Old Mar 27, 2007 | 02:29 PM
C_Williams@RPM's Avatar
0C_Williams@RPM
Former Vendor
Love the Katech stuff and recommend it with their own covers..
However, since they don't sell a universal kit, I thought I'd post the availability of mine here. If this is in any way offensive to Katech, moderators please remove.
I have two kits that work with any covers. Here's the pictures...
Coil Relocation Kit - Moves Coils off Valve Covers
Coil Relocation Kit - Moves Coils over the Valve Covers
Old Mar 27, 2007 | 04:31 PM
vmaquera's Avatar
vmaquera
When the coils are moved off the valve covers, where are they relocated?
Old Mar 27, 2007 | 05:16 PM
WKMCD's Avatar
WKMCD
Here's another look. This is my L92 headed 403.
Old School.
Old Mar 27, 2007 | 05:30 PM
KBlanke's Avatar
KBlanke
Charlie, how much for your kit?
Old Mar 27, 2007 | 08:33 PM
vetterlatethannever's Avatar
vetterlatethannever
Old School.
Sweet!
Old Mar 28, 2007 | 12:17 PM
0C_Williams@RPM
Former Vendor
Here's a picture. Located on the frame rails....nice, cool area.
Complete kit $449
* All hardware SS and anodized aluminum
* Plug 'n Play wiring harness
* Ignition wires
Old Mar 29, 2007 | 12:26 AM
hpcubed's Avatar
hpcubed
How do you attach them to the frame rails? Do they use existing bolts or do you have to drill/tap or what?
Old Mar 29, 2007 | 02:33 AM
John Micheal Henry
Charlie,thanks for the info.The kit that mounts thecoils above the valve covers is exactly what I'm looking for.How much and how do I order. THANK YOU J.H.
Old Mar 29, 2007 | 03:33 AM
jak112460's Avatar
jak112460
Old Mar 29, 2007 | 11:14 AM
0C_Williams@RPM
Former Vendor
John,
The kit pricing is as follows:
Over Cover - with harness - $299
* All hardware - SS and Anodized Aluminum
* Ignition wires
Over Cover - without wiring harness - $189
* Ignition wires
To order, either email or PM me.
Thanks,
Charlie
Old Mar 29, 2007 | 11:39 AM
0C_Williams@RPM
Former Vendor
Yes, drill and tap two mounting holes.
Here's the pricing.
Coil Relocation Kit Pricing
Off Cover - $449
o All hardware - SS and Anodized Aluminum
o Plug 'n Play wiring harness
o MSD Ignition wires
Over Cover - without Plug ‘n Play harness - $189
Over Cover - with Plug ‘n Play harness - $289
Old Mar 29, 2007 | 11:09 PM
thetorch's Avatar
thetorch
Here's the pricing.
Off Cover - $449
How do the over cover mount? What's the harness for?
To Katech Coil Relocation Kit
Old Mar 29, 2007 | 11:16 PM
Flatlander's Avatar
Flatlander
With coils mounted on frame rails are there any problems with rain splashing or water puddles?
Old Mar 30, 2007 | 02:56 AM
C6dude's Avatar
C6dude
Originally Posted by jak112460
Very Sharp...
Old Mar 30, 2007 | 10:46 AM
0C_Williams@RPM
Former Vendor
The over the cover kit mounts to existing threaded holes on the intake manifold. Takes about two minutes to mount.
The harness replaces the factory coil harness. You can can easily use the factory piece, just takes some time to make it fit cleanly. My harness is pre-made and makes the install sanitary and totally plug 'n play.
