rear end swap!
Old Mar 30, 2007 | 09:28 AM
dazman's Avatar
dazman
Default rear end swap!
how hard is it to do a rear end swap and what rear end should i go with????
m6
ms4
heads
headers
im thinking 4.10's because the car is undrivable right now... LOL... or atleast seems that way with the 3.42
ive already done a clutch swap but i dont want to have to take that torque tube down again. can i leave it bolted to the motor?
mike
Old Mar 30, 2007 | 10:24 AM
Chris@East Coast Supercharging's Avatar
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
Gearing a 6 speed depends on a few factors. Mostly being the future torque you will be making with the engine and what the car is used for. Most road coarses the 4.10's are too much and make the track a 4 gear thrack instead of a 3 gear track. For street, drag racing and cruising with a 346 head and cam car the 4.10's are a great choice. You do not have to unbolt the torque tube. Just remove the rear cradle and lower the drive train down to get the rear off. You will have to remove the bolts that hold the tunnel plate to get the drive train low enough to slide the rear off. Its not that hard, if you can do a clutch you can do this..
Old Mar 30, 2007 | 12:34 PM
Mike Mercury's Avatar
Mike Mercury
some tips here:
http://mikemercury.home.att.net/342.htm
Old Mar 30, 2007 | 11:03 PM
jmzvet's Avatar
jmzvet
. I've done 3 rear diff swaps using the above listed info .
Old Apr 5, 2007 | 09:37 AM
dazman's Avatar
dazman
thanx guys... any tips on who is the best rear end builder and best deal???
thanx
Old Apr 5, 2007 | 09:39 AM
Cruise-In V Veteran
thanx
If you are anywhere near us we can do it. If you need to have a set shipped to you, call Phil at DTE
Old Apr 5, 2007 | 11:16 AM
vettenuts's Avatar
vettenuts
I have a friend who is going to East Coast Supercharging to get his done. I opted to have DTE build a unit for me from a use differential I picked up as I want to keep my stock unit intact.
To rear end swap!
