HELP! 12 disc player
Old Apr 1, 2007 | 12:37 PM
latenightlarry's Avatar
latenightlarry
Default HELP! 12 disc player
Recently Bought a 12 disc player off the fourm and parts were rattling around inside spring and bracket . Any one have an exploded view of this unit or ever rebuilt one please PM, Email or PH me . # is 619 607 1740. Thanks Larry
Old Apr 1, 2007 | 05:02 PM
rkhegler's Avatar
rkhegler
Well, I do not have any pictures for you but I had a problem with mine. The changer would not work. It simply kept trying to change and never actually do it. I took the outside cover off and discovered that there was a spring that had apparently come loose and when that happened, the corner of one of the CD trays got bent. It was an easy fix as I simply disloged the CD and bent the tray back straight. I hooked up the spring and it has not failed since that time about 3 years ago. I will tell you this, if you take the cover off, do it on a table with a cloth because mine had about a zillion tiny little springs and skrews that could easily get lost. Good luck.
