Right now I have a limited budget but I'm getting antsy to do something to my 02 LS1. My question is if you had to chose one which would it be? A hotter cam or a set of AR heads(202). Right now I have Dynamax long tube headers w/x pipe, Haltec intake, Borla Stingers, ported throttle body, Ram clutch. I know I should do both at the same time but If you had to chose which one?????????
If you plan to do both heads and cam but only one at a time, I'd for the heads first. The reason for this is that you'd probably want a different cam for you upgraded heads than for your stock heads. If you do the heads first, you won't have to live with a previously installed cam that is best suited for your stock heads.
Do them both at the same time. That way your engine is only down one time.
cam first with right cam and other mods car will be like new to you work done for cam change is not needed for head change. tunning is the only thing that will ave to repeated
Keep in mind that not all cams are best suited for all heads. Some combinations work far better together then other combinations.
Slo C5 (and others) are right. You need to do valvesprings with a cam...so you're already into the heads. Furthermore you usually do the oil pump, underdrive pulley, etc.
Try to do both at once if possible. For the price of the AFR's, you can get some PRC ported 243's AND the install. I haven't seen any definitive proof that AFR's will net you huge hp over other ported heads...usually you're talking 5-10hp at most.
If you are paying for the labor to have them installed then definitely do them at the same time. The cost of labor alone the second time around would be enough to pay for the heads themselves on the first engine mod. You can get a nice set of heads for $1500. Analyze the cost.
If you can afford heads, a cam is only like 400 more right? Just save up and do them at the same time to save on install time and that way you only neeed a single tune.
