Cannot get into 6th gear
Old Apr 7, 2007 | 09:14 AM
86blackt's Avatar
86blackt
Default Cannot get into 6th gear
I took my car out for a spin last night and was unable to put in 6th gear. It went 1/2 way in and I could feel a little grinding, so of course drove around the rest of the night in 5th When I parked it last week, everything was fine. Is there a linkage adjustment or something? I did race a mustang last weekend and wheel hopped a bunch in 1st. Car has a couple bolt ons and is an 01 with 23k miles. Thanks for any help. Rich
Old Apr 7, 2007 | 10:13 AM
willyfastz's Avatar
willyfastz
There's not really any adjustments, I'm not a trans builder but I'd say it's probably a shift fork problem.
Old Apr 7, 2007 | 10:52 AM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
If you have a stock shifter there is an alignment pin in the front of the shifter, but based on what you are saying it sounds like a bad synchro.
I would contact Rodney or Todd at RPM tranny.
Old Apr 7, 2007 | 03:24 PM
cenzo's Avatar
cenzo
http://www.rpmtransmissions.com/links.html
Old Apr 7, 2007 | 09:02 PM
86blackt's Avatar
86blackt
Thanks Cenzo, I will try the adjustment procedure. It was really freaky that I had the issue yesterday, but not the last time I drove it. I just bought it about 500 miles ago. Once again, thanks, and I will check back in after I adjudt it!!
Old Apr 19, 2007 | 09:02 PM
86blackt's Avatar
86blackt
I am going to try adjusting this weekend. Is there any special tricks to removing center console? Thanks Rich
Old Apr 20, 2007 | 03:54 AM
tstar's Avatar
tstar
St. Jude Donor '11-'12-'13-'14-'15
Use this down to step 3G;
http://www.vetteessentials.com/instr...zel_howto.html
Old Apr 20, 2007 | 10:07 AM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Can you shift it into 6th with the engine off??
BC
Old Apr 20, 2007 | 12:50 PM
86blackt's Avatar
86blackt
Will not shift into 6th when off either. Do I have to remove center console to adjust likage? Thanks Rich
Old Apr 20, 2007 | 01:11 PM
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
You MIGHT be able to get to it without removing the console but it will be tough. It take 10 mins to remove it.
BC
Old Apr 20, 2007 | 02:55 PM
Oldvetter's Avatar
Oldvetter
Changing clutch fluid and transmission fluid fixed mine. These transmissions are sensitive to dirty fluid. I had Mobil 1 synthetic fluid in for 60,000 miles, changed to Amsoil ATD.
Old Apr 20, 2007 | 04:50 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Don't see how you're going to do it without removing console or breaking your shift boot.
It sounds like you have a bad fork or synchro. If you can get all of your other gears and just not 6th, I don't think any adjustment is going to make a difference.
Good Luck.
Old Apr 20, 2007 | 08:21 PM
86blackt's Avatar
86blackt
Car ran fine, no grind, no nothing. I raced a mustang, had a bunch of wheel hop in first last time I drove it and now nothing. The shifter goes all the way back like it is in it's position. If I had a bad syncro I would be able to put it in gear with motor off, or am I wrong about that? If it had a bad fork, would it let the stick go into position? I am not forcing it at all. Also, it looks as though there is an adjustment made from under the car,or am I seeing it wrong. Thanks for everyone's input!! Rich
Old Apr 20, 2007 | 10:17 PM
tstar's Avatar
tstar
No there is no adjustment from under the car for your shifter. You might have seen a reference to the Anti venom mod?
Anyway, I'd try to allign the shifter and see what you have... If you want a comprehensive version PM me your EMil address.
Tim
Old Apr 20, 2007 | 10:39 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
Sorry didn't catch the no grind. Probably a bent fork that won't go back far enough to engage the sixth gear, only way to figure it out what is wrong will be to R&R the tranny.
I highly doubt it is a shifter alignment problem as all of the other gears work fine.
Do use an after-market shifter with stops ?
Old Apr 21, 2007 | 07:34 AM
86blackt's Avatar
86blackt
stock shifter. Can the fork bend without being forced into gear? How does that happen...DO I GOT JUNK??? 23k miles??
Old Apr 21, 2007 | 08:15 AM
86blackt's Avatar
86blackt
Also, feels like gear shifter goes into fork, and when I release the clutch, slight grind, like it is barely sitting on gear. I push in clutch and try to get it in again, same.
Old Apr 21, 2007 | 09:38 PM
86blackt's Avatar
86blackt
Wanted to thank everyone for their input, shifter adjustment took care of the problem!!
Old Apr 22, 2007 | 01:50 AM
tstar's Avatar
tstar
Excellent!
To Cannot get into 6th gear
