Ls1 Edit?
Old Apr 7, 2007 | 09:21 PM
vettegator005's Avatar
vettegator005
Default Ls1 Edit?
I have LS1 edit on my 99 c5 and iam trying to add modifications to it which require a retune but the guys that i took it to said LS1 edit is locked by the orignal tuner and only he can unlock it. Anyone here know if this is true? If so is there anyway to find the code without taking the car to the orignal tuner?
Old Apr 8, 2007 | 12:12 AM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
theres no other way to unlock it. 1 option is to buy a used PCM and then have it tuned from scratch.
Old Apr 8, 2007 | 09:32 AM
B-Vette's Avatar
B-Vette
I guess that's one way to get a repeat customer.
Old Apr 8, 2007 | 10:22 AM
vettegator005
Damn. But i can buy a different pcm and just slap it in there and mess with it all i want?
Old Apr 8, 2007 | 10:30 AM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Unless you have the original PCM download from "your" car, another PCM isn't going to do you much good without taking it to the dealer to have them reflash it to "your" car. Also, within the PCM and BCM, there is a security feature of a secret password between them. If the pasword doesn't match on both computers, the car will not run. I suggest that you take it to the dealer and have them reflash the exisiting PCM back to factory specification for your car. From that point you can use LS1Edit to make modifications to your tuning and a hint here...make sure you save the first download of your factory flash tuning to a file in your laptop that you then make several copies of in different places and burn it to CD. If you ever take it to a tuner, insure you tell them not to lock it.
Old Apr 8, 2007 | 10:56 AM
vettegator005
So even if the dealer doesnt know the code of the LS1 edit they can reflash it back to stock?
Old Apr 8, 2007 | 03:31 PM
corvettebob1's Avatar
corvettebob1
Yes the dealer can reflash it back to stock even if it's locked by a tuner.
And not all tuners lock the PCM when they use LS1 edit.
Old Apr 8, 2007 | 06:08 PM
Funn One's Avatar
Funn One
Old Apr 8, 2007 | 07:13 PM
vettegator005
Thank you guys very much corvette bobb and funn one you answered all my questions im gonna go get it reflashed,retuned and slap on a lot more parts.
Old May 1, 2007 | 06:02 AM
fil131's Avatar
fil131
Default Dont know if you fixed it yet
You can always go to the tuner and request an unlock, they will need your car present.
If they want good business I would think they would be willing to help you out.
Hope this helps, I know the dealer can be very pricey.
Fil131
Old May 1, 2007 | 08:01 AM
auctiondepot's Avatar
auctiondepot
Default I think you can
Email the carputing people and ask for help
info@carputing.com
You will need their programing software to unlock it.
you download your PCM file, send it to them, they unlock it, load it back in and you have control of your property now.
I'm not sure if HPtuners will have the same service, perhaps they do?
To Ls1 Edit?
