Losing RWHP with MODS..
Old Apr 8, 2007 | 08:18 AM
qwkz06's Avatar
qwkz06
10 hp increase from replacing your shorties with the Bassani headers at the same time as you went from a 3:15 to a 3:42 gear is not bad at all. The gear change causes a loss of some hp but I bet the car woke up. What surprises me is a drop in tq with those headers. Are they the Tri Y's? Do you have an X pipe. Those headers usually make great torque.
Old Apr 8, 2007 | 11:06 AM
vettenuts's Avatar
vettenuts
Can you post the dyno curves? I agree that the cam change would net minor gains, although there may be more area under the curve. Is each dyno done with the converter locked? The FAST 78, properly ported, should net you about 15-18 hp. Careful of the Patriot heads as well, what is their port size? You might pick up peak numbers and lose low end fun.
Have you done any dynamic compression ratio calculations? What is your current compression ratio (static)? Where are you trying to make the power? Be careful of changing things between dynoes (motor parts/gears) as you can easily lose track of what is happening.
Old Apr 8, 2007 | 03:46 PM
SLPRC5's Avatar
SLPRC5
First dyno was the best with the mods... The headers are Tri "Y".. I have the "X" pipe and hi-flo cats ZO6 Ti exhaust.
I think it's the dyno or operator.
Old Apr 8, 2007 | 05:28 PM
SLPRC5's Avatar
SLPRC5
I have the stock TC. I'm not sure if he dose the dyno in 3rd with the traction control off...I noticed the stop limiter shuts off at 6300 RPM.
I took off the FAST 78 and replaced it with the LS6.
I have no idea of the compression ratio calculation/current compression static.
Dyno 1 with the shortie headers and ZO6 cam and heads.
Max power 349.31 Max TQ 351.11
Dyno 2 after replacing the shorties with Bassini LT headers:
Max power 359.66 Max tq. 344.22
Dyno 3 after 224/224/ .567.567 LSA114 cam installed
Max Power 360.69 Max TQ 344.16
Final dyno by first tuner
376 RWHP and 350 RWHP
I hope you can make sence of this.
It look like a bad tune or dyno.
Old Apr 8, 2007 | 06:31 PM
vettenuts's Avatar
vettenuts
Where was the first dyno done, can you go back there and get a pull for comparison. Otherwise, to figure it out you would need to convert them all to a consistent scale and plot them with Excel. Different dynoes will give different results as well. I have been told the one I use in Mass is stingy on the numbers, not sure if it is true or not, but it works well as a parametric tuning tool.
Old Apr 8, 2007 | 07:03 PM
SLPRC5's Avatar
SLPRC5
Thanks. I understand that different dynos give different numbers and it's best to stick to the same dyno and tunner to ensure better accuracy.
I'm trying to decided if to go back to the first dyno place before installing the heads or wait until I have the heads installed to see how the number vary between the two dynos. I know the first pulled up my dyno numbers from 322 RWHP from a street tune to the 349.31 RWHP (this was after he installed a '98 pcm program into my '97 pcm)
Thislast tunner may have a problem tunning a A4..because he does a lot of M6s.
Old Apr 8, 2007 | 07:59 PM
vettenuts's Avatar
vettenuts
If its easily accessible, I would just go to the first place and have them do a pull to baseline the car from where you are now prior to doing the heads. This would help remove variables later when you are trying to figure out what you have gained.
Old Apr 8, 2007 | 08:03 PM
SLPRC5's Avatar
SLPRC5
Thanks Buddy, you have always led me and others in the right direct.
I'll try and setup one this week with the first dyno guy.
Hope you and your family had a Happy Easter
Old Apr 8, 2007 | 11:09 PM
Z064FUN's Avatar
Z064FUN
Have you noticed a SOTP difference with each set of mods?
Old Apr 8, 2007 | 11:25 PM
SLPRC5's Avatar
SLPRC5
Yes I have. more so with the cam install...but why such small gains with installs???
Old Apr 8, 2007 | 11:32 PM
Z064FUN's Avatar
Z064FUN
Maybe it is something in your transmision or a problem with your torque converter. As long as it feels stronger all is well. Do you ever take your car to the track? Any improvement in 1/4 times?
Old Apr 8, 2007 | 11:49 PM
SLPRC5's Avatar
SLPRC5
The tranny is strong, as for the TC it is stock.
Never have gone to the track..but been told that is where to tell the gains. One guy who has driven my car and is track junkie says he bet my car is in the high 11s on street tires...
Old Apr 9, 2007 | 12:05 AM
  #33
Z064FUN's Avatar
Z064FUN
11's sounds a little optimistic, but a great excuse to take it to the track! We usually get a group of vets going to sac a couple times over the summer, love to see ya there.
Jade
Old Apr 9, 2007 | 01:43 AM
  #34
SLPRC5's Avatar
SLPRC5
Jade
Yep..one way to find out is to go to the track. So i'll have to make it to one of them...
Old Apr 9, 2007 | 02:08 PM
  #35
SLPRC5's Avatar
SLPRC5
Bump
Old Apr 11, 2007 | 10:17 PM
  #36
SLPRC5's Avatar
SLPRC5
Much better numbers in RWHP and RWTQ after tune done today by my first tuner in 06.
I gained 16 RWHP and 5RWTQ on this tune.
The tune before this one was tuned too rich along with some other incorrect settings.
Here is the printout of today's dyno on the same dyno and tuner that was used for the first dyno.
Old Apr 12, 2007 | 12:02 AM
  #37
Brad@RevXtremeAutoSports's Avatar
Looks better D.
Been following ur post on this, and I almost feel compelled to offer you your shorties back, well almost.
Good luck bro.
Brad
To Losing RWHP with MODS..
Old Apr 12, 2007 | 01:39 AM
  #38
SLPRC5's Avatar
SLPRC5
Originally Posted by Brad@thecorvetteshow
Looks better D.
Good luck bro.
Brad
Thanks Brad..
Glad you are enjoying the shorties
Next is the Patriot heads to be installed and another tune...this should get me over the 400RWHP I'm looking to get.
The tuner told me today he just did a Camaro A4 with the Patriot heads, LTs and the same cam I have and it got 427 RWHP.
SLPRC5
BTW great looking home page..
Old Apr 12, 2007 | 02:06 AM
  #39
mvvette97's Avatar
mvvette97
St. Jude Donor '06-'07-'08-'09
something i don't understand, as posted earlier about losing HP with lower gears, How can that be? If anything I would think it would gain HP with lower gears. It sure feels like it anyway. Can somebody explain this to me?....Marc
Old Apr 12, 2007 | 02:39 AM
  #40
SLPRC5's Avatar
SLPRC5
what's with that?
