Losing RWHP with MODS..
Old Apr 12, 2007 | 03:12 AM
  #41
427CPE's Avatar
427CPE
Originally Posted by tblu92
Hello just a few thoughts on what i can see--There really isn't a whole lot more HP to be gained between the LS6 cam and your 224@114cam.To make some better #'s you need to get the LSA down to at least 112 and that would make the greatest difference---Also---I see your WOT AFR keeps dropping---from 12.8 to 12.6 to 12.3 You are leaving some power behind there--You need to get it back up to 12.8 again.Also What is your total timing @ WOT ??? with 10.750-1 comp ratio and good gas you should make best power between 24-28* just as an approx guess. Long tubes even cheap ones tuned properly should gain 20 RWHP always ......I have STOCK LS6 heads and a .221 cam @114 (calif smog legal) long tubes and a good tune and I made 380 RWHP with a Fast 78mm manifold on an A4.
I tend to agree w/this statement. Exh Scavening w/cams greater than 112 LSA is sort of a waste of time. Don't forget he is also bleeding off cylinder pressure w/that cam. Cam timing events don't match stock, so spark is probably off too. Sounds like time for a good tune up to match the package.
Old Apr 12, 2007 | 10:04 AM
  #42
SLPRC5's Avatar
SLPRC5
I didn't want a choppy idle so I went with the LSA114. This cam has to be much better than the 2002 ZO6 cam.
I do have a better tune as of yesterday. Went from 360RWHP to 376RWHP torque went up from 344RWTQ to 350 RWTQ.The tune before left a lot of horses in the stable by tuning too rich.
Next is Patriot heads to install.
Old Apr 12, 2007 | 10:33 AM
  #43
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
It's the Heads!
If you go with a set of Patriot Heads you will deffinetely see a big difference and will Dyno higher!
If you still want to get better numbers go with the TFS Heads(Trick Flow) It will push your combo to where I believe you should be! These heads will surpass the Patriot's far and wide!
Remember that any combo is as good as the heads are!
Thanks,Matt
Old Apr 12, 2007 | 01:43 PM
  #44
mvvette97's Avatar
mvvette97
St. Jude Donor '06-'07-'08-'09
Old Apr 12, 2007 | 02:14 PM
  #45
SLPRC5's Avatar
SLPRC5
Originally Posted by madmatt9471
It's the Heads!
Thanks,Matt
Sorry to say I already have the Patriots sitting waiting to be installed...people have also been geting good results from these heads i.e. Camaro A4 with Patriot heads, 224/224 cam and American Racing headers 427 RWHP..
Old Apr 12, 2007 | 02:30 PM
  #46
EV2DEMON's Avatar
EV2DEMON
Originally Posted by mvvette97
something i don't understand, as posted earlier about losing HP with lower gears, How can that be? If anything I would think it would gain HP with lower gears. It sure feels like it anyway. Can somebody explain this to me?....Marc
You don't loose HP at the engine, the Dyno just measures less.
The faster you accelerate something, the more power it takes. Steeper rear gears mean that the drivetrain will accelerate more quickly, so more power is consumed due to parasitic loss. The engine is still making the same power, and the car is accelerating more quickly thanks to increased torque multiplication, but the actual measured HP is lower because more of the engines power is required to accelerate the drivetrain quicker.
Old Apr 12, 2007 | 02:35 PM
  #47
chaase's Avatar
chaase
St. Jude Donor '12
It's the Heads!
Thanks,Matt
The initial mod set is LS6 heads + ST headers. You add LT and gears and get more power. Then you add a cam and don't get any more power. With stock heads, I wouldn't expect to get massive gains from one cam to another.
I have a similar cam (not sure of the exact spec) and I put down 419RWHP/389RWTQ on an A4 w/3.42's
Old Apr 12, 2007 | 02:36 PM
  #48
flynbya2's Avatar
flynbya2
St. Jude Donor '05-'06
OOOh,
I am watching this sleeper!
You have almost mirrored my mod setup(I am jumping up to lg pro's real soon from shorties,next the cam.........and I just installed the 3:42's)
My last dyno was 337/342 w the stock ls1 cam,243's and 3:15's
It'a actually really neat that our mods are so close,at certain points..
I was thinking of going with the same cam, but maybe a 228 ex duration.
I wonder if that would gain anything over the straight up 224 cam( prolly not much)
Anyways, I am around, watching my new mods come to pass
Thanks for doing all my research!
BTW,Those are real nice numbers for stock 243's and an a-4!
Old Apr 12, 2007 | 03:44 PM
  #49
vettenuts's Avatar
vettenuts
Finally got to see the curves (the attachments are blocked at work). Looks like you not only gained on peak, but in the lower RPM's as well
Old Apr 12, 2007 | 05:01 PM
  #50
SLPRC5's Avatar
SLPRC5
Originally Posted by flynbya2
OOOh,
Thank you very much for the comments. This what the forum is about helping and learning.
o
I recommend that you go with American Racing headers. They come with cats for around $1700.These gain some great HP over the Bassanis I have.
Come to find out as I was told that hi-flow cats don't last long. I have the Magnaflow hi- flow cats and one or both are going bad.I may go back to OEM cats if there isn't too much of a HP lost.
Heads are next as soon as my lifters come in.
Old Apr 12, 2007 | 05:03 PM
  #51
SLPRC5's Avatar
SLPRC5
Yes you can feel the car pulls a lot better. This tuner was the one who did my first tune...the guy is GREAT!
Old Apr 12, 2007 | 05:37 PM
  #52
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
Originally Posted by Z064FUN
Maybe it is something in your transmision or a problem with your torque converter. As long as it feels stronger all is well. Do you ever take your car to the track? Any improvement in 1/4 times?
A stronger torque converter will work wonders to your power to the rears.
If you're using the bassini 4-2-1 headers, you'll get a much stronger midrange but sacrifice peak HP/Tq at the higher RPMs. The 4-1 design is best for maximum power but you only get it around 5K RPM
Old Apr 12, 2007 | 05:50 PM
  #53
SLPRC5's Avatar
SLPRC5
I'm not sure of the design, they are the newest ones out. I think four tubes go into the collector. On the dyno the tuner brought it up to 6300 RPM so I guess they reached their HP peak.My tuner doesn't like them for two reasons. 1. He said the tubes aren't big enough and 2 they use clamps to hold tehm together and he said they will end up leaking.
Old Apr 12, 2007 | 09:05 PM
  #54
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
I can't seem to find any specs on the bassini site that match your description...but they don't have any pictures. I agree about the clamps. Depending on the material. you might try getting a good welder to seal them up.
Old Apr 12, 2007 | 09:29 PM
  #55
SLPRC5's Avatar
SLPRC5
Good idea about the welding. If and when it happens, I'll do that.
Old Apr 12, 2007 | 11:59 PM
  #56
mvvette97's Avatar
mvvette97
Ah, I understand. Thanks for the info.
Old Apr 13, 2007 | 06:15 AM
  #57
vettenuts's Avatar
vettenuts
I believe the only header that Bassani makes is a Tri-Y design. I have the QTP's, which are a stainless Tri-Y design. If you read some of Burn's articles, he prefers a properly tuned Tri-Y to the 4-1 header design.
Old Apr 13, 2007 | 01:18 PM
  #58
SLPRC5's Avatar
SLPRC5
Thanks for that info..it makes me feel better
