Disconnecting Battery for Replacement or Winter Storage
Old Apr 8, 2007 | 12:29 PM
sprill's Avatar
sprill
Default Disconnecting Battery for Replacement or Winter Storage
If I want to replace or disconnect my battery for winter storage will I lose any settings like the radio stations, memory seats, etc.
Thanks----
Old Apr 8, 2007 | 12:49 PM
mickey_7106's Avatar
mickey_7106
Old Apr 8, 2007 | 12:54 PM
B-rent's Avatar
B-rent
Yep anytime you disconnect the battery it loses the presets. Not a big deal just takes a few mins to reset everything
Old Apr 8, 2007 | 05:02 PM
DeeGee's Avatar
DeeGee
If you have a stock radio with the security code set, either disable it before you disconnect or check out the Tech Tip on how to unlock it. It'll be locked when you reconnect.
Old Apr 8, 2007 | 05:38 PM
87SAM's Avatar
87SAM
Not necessarily, I’ve had my battery disconnected for more than a week and other members have gone even longer without losing presets. Don’t know if there is a time limit though.
Yes, a very good idea to check to see if you have the lock code activated or not.
Old Apr 8, 2007 | 06:00 PM
B-rent's Avatar
B-rent
I guess it depends on the car, I can disconnect mine for 5 mins and it makes me reset everything.
To Disconnecting Battery for Replacement or Winter Storage
