Crank Pulley Install Tool
Old Apr 10, 2007 | 09:11 AM
94legaleagle's Avatar
94legaleagle
Default Crank Pulley Install Tool
Couple months or so ago, I started a thread where I "paid it forward" with a Crank Pulley install tool - I had borrowed the tool with the agreement that when I was done, the tool just kept getting sent on to the next needy/worthy individual for their use -
I now have to swap springs in my oil pump and I need the pulley install tool back - but I don't remember who I forwarded it to, and I don't know where the tool is at - ANYONE have the Crank Pulley Install Tool that I am referring to? PLEASE.
Whoever has it, could you PM me so that we can discuss getting it back to me for my TEMPORARY use? - When I'm done w/ it, the "forward it on" chain will continue - I SHOULD have been done with it, but my oil pressure is TOO high, so's I gotta pull the front apart and swap oil pump springs.
THANKS MUCH!
Old Apr 10, 2007 | 09:13 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
If you haven't found it by Saturday when I get home I'll loan you mine.
Old Apr 10, 2007 | 11:32 AM
Brad@RevXtremeAutoSports's Avatar
anyone have a source for the parts to make this thing. I mistakenly thought i could find the parts in Tampa, but no luck.
TIA
Old Apr 10, 2007 | 03:21 PM
94legaleagle
THANKS I PM'd you - my car's gonna start to like the parts you supply
Old Apr 10, 2007 | 07:40 PM
vettenuts's Avatar
vettenuts
TIA
Got mine from McMaster-Carr. 300 mm long threaded rod, nuts and I had the washers.
Old Apr 10, 2007 | 07:52 PM
see5's Avatar
see5
If you warm the pulley up in the oven you can tap it on with a 2x4 and a couple whacks with a hammer.
Old Apr 11, 2007 | 05:07 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
PM returned and I'll box it up Friday then ship it out to you Saturday.
Old May 27, 2007 | 06:22 PM
2.0 or 1.5 ??
TIA
Brad
File Type: pdf
Old May 27, 2007 | 07:07 PM
vettenuts's Avatar
vettenuts
Thread pitch is 2mm.
Old May 27, 2007 | 08:19 PM
Thanks bro, going with a bigger cam.
Brad
To Crank Pulley Install Tool
