oil Vararam filter before install?
Old Apr 11, 2007 | 07:41 AM
Cobraboy's Avatar
Cobraboy
Default oil Vararam filter before install?
Just got my Vararam last night and had a quick look at it. It's the new one with the "green" filter, which, from what I've read, is very similar to a K&N. The instructions just say to install it as is, but it looks dry to me. Should it be oiled (with a K&N cleaning kit) before installation? Do others just install it as it comes? From what I remember, the K&N filters come pre-treated with oil, couldn't really tell if this one was or not.
thanks,
Rick
Old Apr 11, 2007 | 08:30 AM
rws.1's Avatar
rws.1
PM CF member VaraRamIndustries and get it the correct answer directly.
Old Apr 11, 2007 | 01:01 PM
Cobraboy's Avatar
Cobraboy
Thanks, I did that. Apparently you are supposed to pre-oil the filter. Wonder how many people knew that?
Rick
Old Apr 11, 2007 | 07:01 PM
GreyGT-C's Avatar
GreyGT-C
i was told this weekend that the filter oils will damage the MAF sensor....
Anyone have any input on this???
Old Apr 11, 2007 | 10:05 PM
Cobraboy's Avatar
Cobraboy
I think it's important to not use too much, and give it time to "dry" (soak into the fabric filter). Otherwise it will come off and coat the MAS wire.
Rick
Old Apr 12, 2007 | 12:52 AM
Bluefire's Avatar
Bluefire
Use a VERY light oil and a fine mist spray bottle to apply it. Too much oil will foul the MAF and make your car run lean and knock. Don't ask me how I know.
Old Apr 12, 2007 | 05:56 AM
vettenuts's Avatar
vettenuts
If the filter is truly "green" it should already be oiled. I also wouldn't use the K&N kit on the green filter as the cotton used in each is different with K&N being a mat and the green being a weave. Not sure if the oil that each uses accounts for the cotton differences with a viscosity or some other change to the oil. I also didn't think Vararam was using the green filter any more, but rather what they refer to as their "grey" filter. When I had mine, I contacted Vararam and they told me they weren't using the green filter and I couldn't buy it, this was about a year ago.
Old Apr 12, 2007 | 10:16 AM
Bluefire's Avatar
Bluefire
I talked to VaraRam when I installed mine, they told me that the Green filter was for the C6 and the Grey filter was for the C5.
Old Apr 12, 2007 | 10:23 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
NO! Only happens when one puts a ton of oil on the filter. Just put a few sprays on it and all will be good!
Thanks,Matt
Old Apr 12, 2007 | 04:00 PM
superjet701k's Avatar
superjet701k
i have a c5 and grey filter also instructions say use wd40 to oil it
Old Apr 12, 2007 | 04:20 PM
max'svette's Avatar
max'svette
St. Jude Donor '11
Oh oh . I thought it was a K&N filter. So I used K&N filter oil on the filter?! As well as the K&N cleaner.
Isn't there a replacement K&N filter for the Vararam?
Old Apr 12, 2007 | 06:56 PM
Ralphyboy's Avatar
Ralphyboy
St. Jude Donor '08-'09
The instructions with my Vararam said to install the filter, but did not mention oiling the filter.There was a section in the instructions about cleaning the filter only. I quote:
"Cleaning the filter
Any aftermarket filter cleaning kit will work.
If you choose not to use an aftermarket cleaning kit, wash using warm water from the back side of the filter.
Use liquid detergent, lather filter very well and then rinse again from the back side of filter.
You may dry filter with hair dryer, or let dry naturally.
Once dry, re-oil filter with any aftermarket filter oil or we prefer WD-40."
So, what the heck do you do?Are you supposed to oil the filter before you install it the first time? Cobraboy says Vararam told him to oil the filter first. You know, I have some issues with Vararam now. Their instructions SUCK. If not for cajundudes info on the install, I'd still be messing with it, and now this stuff about the filter. I'm NOT HAPPY.The fact that this is a "next" generation product implies that all these questions and bugs should be worked out already.
Old Apr 12, 2007 | 07:19 PM
max'svette's Avatar
max'svette
St. Jude Donor '11
Can anyone confirm if this is a Vararam or K&N Filter?!
Old Apr 12, 2007 | 08:38 PM
ZZOOM06's Avatar
ZZOOM06
That's the K&N
Old Apr 12, 2007 | 11:41 PM
Cobraboy's Avatar
Cobraboy
Yes, I was just told by VaraRam that the filter should be oiled before being installed. I does kind of bother me that the instructions don't say this (though they do describe how to clean and then oil it). Since the instructions do say it is OK to use WD-40 or "any aftermarket filter cleaning kit", I think I'm going to oil mine with the K&N stuff. The reason is that I thought WD-40 basically evaporates and only leaves sort of a dry-lube after a while, and I think the filter should be slightly wet with oil. Can't see any harm using a proven oil (K&N). Of course K&N says to never use WD-40 on their filters, but that may just be because they want you to buy their oil (or am I just being synical).
Rick
Old Apr 13, 2007 | 07:45 AM
VaraRam Industries's Avatar
VaraRam Industries
Supporting Vendor
St. Jude Donor '07-'11-'12
This appears to be our C5 filter after being coated with K&N filter oil. The C5 filter is "gray" in color and does not come preoiled. A very light coat of filter oil or WD 40 is suggested. The C6 unit comes with a "Green " filter and it is preoiled (hold it up to your nose and smell).
As stated - don't overoil the filter as you will pull oil on the MAF and throw codes!!! A very light coat is all that's needed. If anyone has any confusion on their filter PM or call me at 866-507-2648 and I will answer your questions.
Steve
Old Apr 13, 2007 | 04:42 PM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
My grey filter is mesh like with a screen on the back side. which filter is that ?
To oil Vararam filter before install?
Old Apr 13, 2007 | 05:56 PM
superjet701k
WELL IM GOING TO SAY IT your over analizing this its a filter there all the same who cares who makes it. there cotton/cotton guaze whatever, nothing new they have been around for 20 years ive used everthing laying around the shop from all-in-one oil to wd40. dust sticks to oil mystery solved just dont drowned it less is more. but hey ive never built a complete space shuttle just a few parts.
Old Apr 14, 2007 | 04:50 AM
VaraRam Industries
Supporting Vendor
Sounds like you have the older "foam" filter.
Old Apr 14, 2007 | 07:09 AM
phils C5 vette
Yes I think it is.
Are they still safe to use ?
