Air Intake Flaws
Old Apr 11, 2007 | 06:31 PM
versacestl's Avatar
versacestl
Default Air Intake Flaws
This post is not inquiring about which models are the best or most favored but which models you have had issues with. Im not concered about the 1-2 hp gains or difference between most models , since that sort of gain is not really trivial even more so noticed, but i am concered with quality and any issues that are known. If you could be so kind to tell me what intake you have and your outlook on it, that would be great.
Also does a double intake make a noticible difference in hp gain and sound?
As opposed to:
Old Apr 11, 2007 | 06:57 PM
1KLRTOY's Avatar
1KLRTOY
Originally Posted by versacestl
This post is not inquiring about which models are the best or most favored but which models you have had issues with. Im not concered about the 1-2 hp gains or difference between most models , since that sort of gain is not really trivial even more so noticed, but i am concered with quality and any issues that are known. If you could be so kind to tell me what intake you have and your outlook on it, that would be great!
Ihave the Callaway "Honker" and have 0 issues with it, its a top quality CAI
Old Apr 11, 2007 | 07:50 PM
Gohard777's Avatar
Gohard777
As opposed to:
personally, I feel that the motor is only going to suck in so much air to mix with the fuel, and I feel as you do about the HP increases, so it comes down to a matter of choice, and I went with the top model, figured why not get looks and performance....sounds great too....
Old Apr 11, 2007 | 07:53 PM
versacestl's Avatar
versacestl
So you got the double air intake? How does it do on air (Hot / Cold)? Since it doesn't looks like its designed to be a CAI? Any problems with it?
Old Apr 11, 2007 | 09:09 PM
vettenuts's Avatar
vettenuts
I had a Donaldson first, very nice quality filter but no cooler air. I then had a Vararam, cool air but poor quality and the filter was small and a poor fit. I now have a Callaway Honker, excellent quality, large filter and cool air all in one unit. I am very pleased with this setup and it will be the last one I buy.
Old Apr 11, 2007 | 10:14 PM
Humanoid 2.0's Avatar
Humanoid 2.0
St. Jude 15 Year Donor
Cruise-In VII Veteran
St. Jude Donor '05 thru '19
Another vote for the honker
Old Apr 12, 2007 | 12:38 AM
dndrsn's Avatar
dndrsn
I made my own Cold Air Induction. I have had no issues with it whatsoever and am very satisfied with its performance, and it looks good too. I don't get to drive as much now though because I bought beer with all the money I saved.
Old Apr 12, 2007 | 07:25 AM
BudgetPlan1's Avatar
BudgetPlan1
St. Jude Donor '09-'10
OEM Quality
Went from stock to Z06 airbox to Blackwing to Honker. 1/4 mile showed pretty much no difference between Z06 airbox and Blackwing. I'm pretty much guessing than any air induction that isn't pulling outside/cooler air (VaraRam, Honker) really isn't gonna do much for ya'.
Prolly' more about the quality of air than the quantity.
Old Apr 12, 2007 | 07:47 AM
DRR's Avatar
DRR
Vortex Rammer here - great quality, true cai, harder to clean. The filter sits below the radiator shroud, with a hole cut thru the shroud.
Old Apr 12, 2007 | 08:14 AM
George V's Avatar
George V
Honker
Old Apr 12, 2007 | 09:12 AM
AU N EGL's Avatar
AU N EGL
air intake flaws? Ppl tend to put too much oil on the oil paper filters. That oil gets into the mass air flow senser.
I dont oil my filter paper, just blow it out from the inside out with an air hose. YES I know the manfature says not to do that, but I want to get the dirt off the out side of the filter paper.
I have two filters and change them back and forth frequently. Clean air filters provide clean air for your car to breath.
Another topic that is of debate is the doul vs single air intake. Twin or doule air intakes MAY cause a vortex of swirling air in the intake, not good for combustions.
Ram air is a myth at speeds below 600 mph.
any CAI is about the same as any other CAI.
Old Apr 12, 2007 | 09:48 AM
madmatt9471's Avatar
madmatt9471
From: Palmdale, Ca----- 2009 Cyber Gray 4LT A6 F55 452 RWHP 422 RWTQ- RIP 1998 C5 734 RWHP & 585 RWTQ-----
I personally use the VARARAM on my C5. It is one of the best on the market and really it does not get any better!
Although many are about the same in the way of HP gains the VARARAM is the leader of the pack.
Go to www.thelapd.com they have them for $305.00 which is the lowest price around.
Talk to Shawn they are getting a new shippment in today!
You can feel a tremendous difference in them right off the bat!
You will not be dissapointed one bit plus I changed from the K&N FIPK set-up to the VARARAM! much pleased!!!
Thanks,Matt
Old Apr 12, 2007 | 09:58 AM
miami993c297's Avatar
miami993c297
Worked on the subject with accurate logs and data...
AGREE ON EVERY POINT
Christian
Old Apr 12, 2007 | 09:59 AM
TheRadioFlyer97's Avatar
0TheRadioFlyer97
Former Vendor
St. Jude Donor '08
You won't see any significant gains without a CAI. Most all aftermarket intakes will provide you with a good gain for about 10 minutes or so until the car warm up. At that point the underhood temperature causes the warm air intakes to become less effective. (colder air = denser = more O2 molecules = better combustion)
Cole air intakes such as the Honker, Vortex and Vararam aren't affected by underhood temperatures so you get a consistantly cooler temperature for your intake. A quality CAI will show gains of 10-20HP whereas even the best warm air intakes are newr 5-10HP.
Old Apr 12, 2007 | 10:02 AM
Gordy M's Avatar
Gordy M
The only way to make more horsepower is to make the engine run more efficiently. Each cylinder can absorb only so much air/fuel per cycle (unless boosted) the two variables are air and fuel. If you are non boosted then the quality of the air makes a difference. Cooler air is more condense and aids in making more HP, sea level air will make more hp the 3000 ft air under similar circumstance. Fuel can be enhanced by octane and compression ratio (NOS increases the oxygen level and makes more HP).
With that in mind, only a true cold air system will make more HP. The others may make more sound, a dirty filter will rob you of air flow, a smooth coupler will make more noise, but thats about it. Honker, Veraram, Vortex, Icebox, etc. will make more HP. The only way to make a reasonable measure is to dyno the base line, make the changes and immediatly dyno the changes. Each time you go to the dyno, too many variables occur to get accurate data. One of the biggest variables is how much tension is on the straps holding down the rear end.
Nobody has done more extensive testing on the C5 and C6 than GM racing. Look at the C5R and C6R and see what they did.
Old Apr 12, 2007 | 10:08 AM
vettenuts's Avatar
vettenuts
I would agree with this to a point. I found the filter on the Vararam (I had the K&N) was small and I believe restrictive. Once you get a little dirt in there more so. I had some pollen in it for my dyno and lost over 15 hp that a blast of air got rid of immediately. I think that when shopping for a CAI, the filter itself is the critical element and one of the things I like about the Honker is the filter is a nice sealed fit, the pleats are deeper for more surface area and the filter itself is larger (length X width).
Like you, I have two filters for the Honker and keep one at the ready while the other is in the car. While they can be cleaned, the air dry time, etc. puts the car down for a while so I prefer to just swap them out.
Old Apr 12, 2007 | 10:12 AM
AU N EGL's Avatar
AU N EGL
and if you really want to get a few more ponies on the dyno tune, take the air filters OFF when you run the dyno, put some big barn fans infront of you car with the air flow on high.
To Air Intake Flaws
Old Apr 12, 2007 | 11:59 AM
rpm462's Avatar
rpm462
Originally Posted by BudgetPlan1
OEM Quality
Another vote for the Honker here.
Old Apr 12, 2007 | 06:40 PM
mcv's Avatar
mcv
True, the shape of the air path from the filter element to the MAFS is critical. Aiming multiple air paths toward each other is detrimental to high flow rate.
Old Apr 12, 2007 | 07:07 PM
Ralphyboy's Avatar
Ralphyboy
St. Jude Donor '08-'09
I have a Vararam, and once installed, it did seem to give a real SOTP increase in power ,and general smoothness in acceleration.However, the quality of construction, installation instructions,PITA to install, and overall impression with the product is not what I thought it would be. I'm not going to change it now, but if I were to start from scratch, and do it again, I would probably go with the overpriced but probably better overall product, which is the Honker.
