Gravity Brake Bleeding
Old Apr 14, 2007 | 01:56 PM
Toms2001PewterC5's Avatar
Toms2001PewterC5
Default Gravity Brake Bleeding
I have removed all 4 brake calipers on my 2001 C5 Coupe to paint and now need to bleed the brakes. I was planning to do a gravity bleed but have never done one before. In reading the threads on this my plan is to remove most of the fluid in the master cylinder with a turkey baster and replace it with new then place a clear tube on each bleeder valve and place that tube into a container with a couple of inches of new fluid in it. Then open all bleeders and let garvity allow the old fluid and air to flow out untill new fluid shows in each tube. I will make sure to keep the master cylinder full of new fluid. Does it look like I have covered everything? Also does anyone know about how long this will take. I want to plan on doing it when I will have enough time to keep the master cylinder full. All comments and suggestions welcome and thanks in advance for your help.
Old Apr 14, 2007 | 02:05 PM
corvettebob1's Avatar
corvettebob1
Default Gravity bleed
Don't think this will work with ABS, when I flushed my brake system a few months ago it took about 15-20lbs of pressure with a pressure bleeder.
BTW, Motive products sells one for about $50.00 works great!
Old Apr 14, 2007 | 03:26 PM
crause's Avatar
crause
Default Old method?
What is wrong with the old "pump and bleed" method. I finally have my wife properly trained to assist. Don't tell me this will not work on the C5
Old Apr 14, 2007 | 05:46 PM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
Gravity works great it may take a few hours.
Old Apr 14, 2007 | 06:03 PM
LoneStarFRC's Avatar
LoneStarFRC
Heck, with speed bleeders you don't even need her.
They work well.
Old Apr 14, 2007 | 07:07 PM
Last C5's Avatar
Last C5
It will work on the C5, it's my wife it doesn't work well with.
Old Apr 14, 2007 | 07:55 PM
jacks996's Avatar
jacks996
Jacks996
Cruise-In VIII Veteran
I tried to bleed mine the old fashioned way and it didnt work. I ended up using a suction bleeder and did RR LR RF LF. Worked great.
Old Apr 14, 2007 | 08:48 PM
vettenuts's Avatar
vettenuts
I gravity bleed mine all the time. But if you opened the system, not sure if it will purge all the bubbles from the caliper, but the gravity bleed will work. Do one wheel at a time.
Old Apr 15, 2007 | 08:58 AM
Snuckley's Avatar
Snuckley
gravity bleed works all the time for me. suck some out of master then, like above do one at a time.. start with furthest away> RR> LR > RF > LF.. add as you go , DO NOT forget to pump up the pedal slowly at the end...
To Gravity Brake Bleeding
