Keep breaking shifter bolts.................
Old Apr 16, 2007 | 12:15 AM
Brad@RevXtremeAutoSports's Avatar
Default Keep breaking shifter bolts.................
Anyone gone to a stud kit? What size are the bolt holes? Should I go to a bigger size bolt and tap it? Open to suggestions. I have a kirban and love it with the delrin C5r shifter.
Brad
Old Apr 16, 2007 | 02:47 AM
mvvette97's Avatar
mvvette97
St. Jude Donor '06-'07-'08-'09
Don't slam it so hard.
Old Apr 16, 2007 | 05:59 AM
02bpdz06's Avatar
02bpdz06
Get an auto!
Old Apr 17, 2007 | 09:26 AM
I have never been accused of having a light touch.
Old Apr 17, 2007 | 09:28 AM
Originally Posted by 02bpdz06
Get an auto!
That was my second choice.
Old Apr 17, 2007 | 09:30 AM
Anyone know the thread size (1.9?) and bolt length?
I have to tap them due to the breakage, so has anyone gone larger?
TTT one time.
Old Apr 17, 2007 | 10:30 AM
HP_Addict's Avatar
HP_Addict
Use stronger bolts, like a allen head cap screw. No way you should be breaking these bolts. Something is not right here. Do you know how much force it takes to shear a 1/4" bolt?
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Brad
Which bolts are you breaking? The housing bolts????
If its the housing bolts that hold the shifter to the box, I wouldn't go bigger cause the aluminum around the bolt holes will get thin. If your breaking the two bolts that hold the box to the tube, you may be able to go bigger. Have you tried grade 8 fasteners??? Home depot or true value hardware have them.
I also have the KIRBAN and LOVE IT too!!
Bill C
Old Apr 18, 2007 | 11:36 PM
Bill and HP, thank you I am off to HD for the bolts you mentioned. Appreciate the feed back.
Brad
To Keep breaking shifter bolts.................
