C5 Vs C6 IRS...
Old Apr 16, 2007 | 02:42 AM
N0TDADYS_98's Avatar
N0TDADYS_98
Default C5 Vs C6 IRS...
Is there a difference between teh C5 and C6 irs...
Could one installl a c6 irs in a c5 and or could you install a c5 diff in a c6. i've noticed some of the parts are the same.
Old Apr 16, 2007 | 01:14 PM
N0TDADYS_98
bump for the day crew.
Old Apr 16, 2007 | 02:01 PM
flynbya2's Avatar
flynbya2
St. Jude Donor '05-'06
I would bet you could pull off swapping the c-6 A arms/cradle into a c-5
( I think I read Lou Giggliota is running this in one of his cars)But I am not as sure about the diffs interchanging,it would be nice to know if they did though
Maybe someone with experience in both will chime in...
Old Apr 16, 2007 | 03:42 PM
AU N EGL's Avatar
AU N EGL
First of all, why do you want to do this? The C5 is wider then the C6. IIRC the C6 1/2 shafts are shorter then the C5 1/2 shafts.
Second, Yes there have been severl WC C6s that started out as C5 chassies, but rear mounting points, a-arms were changed. Also coil overs were used, vs the leaf spring.
There are several differnt differentials for both the C5 and C6.
Old Apr 16, 2007 | 04:15 PM
N0TDADYS_98
ok.. i guess i need to give more information.. I'm not so much interested in the who IRS.. more or less the diff.
i'm thinking about getting a C6 in a year or so... but i'm also wanting a built rear for my c5. so i was thinking if they can be interchanged i'd go all out on a DTE diff and swap them when i get the C6. Assuming this is a possiblity...
Old Apr 16, 2007 | 09:26 PM
NSTG8R's Avatar
NSTG8R
im going to go ahead and tell you the bad news .. not gonna happen.
the 05's were the same (i believe) but in 06 the diffs were changed, i dont know if they bolt up anymore.
just get it and get another one for the c6 (if or when) you get it.
Old Apr 17, 2007 | 12:52 AM
N0TDADYS_98
not bad news... i'd probably get an 05 anyways..
To C5 Vs C6 IRS...
