Help w/ Pinging
Keep us up-to -date on your progress.
BC
You changed the (expensive) knock sensors but your bulking at changing inexpensive spark plugs. Checking the fuel pressure is a is recommended and very easy to accomplish.
There are a couple of main things that could cause ping:
- Lean mixture
- Aggressive timing curve
- High cylinder temp
- High cyl pressure
You say that you used Sea foam but,,,did you use it correctly? If you just sucked it into the intake until the bottle was empty and then shut down the engine,your intake is really clean but your cylinders are still dirty, You need to have someone throttle up the engine to around 1500-2000 RPM and while the vacuum is pulling sea foam out of the can, have the person "TURN OFF THE ENGINE' and let the engine coast to a stop while you allow raw sea foam to continue to be sucked into the engine. That way, you have raw sea foam sitting in the cylinders and if you let it sit over night, it will do it's magic. Yep, it will smoke like crazy the next morning!
If you do the sea foam cleaning and it still has an issue with ping, have someone with tuning software examine the engine parameters. Thats your best bet. Get it done before you suffer engine damage if it is really knocking.
BC
I did put some SeaFoam in the gas tank afterwards and did notice a difference but just haven't got the nerve yet to put it in the intake.
I think your right that once SeaFoam is in there sitting for a while, most if not all our problems will be solved.
I'd be willing to bet people like my self who do a lot of normal freeway driving with a 2.73 in the rear have this problem the worst. The upside to this is that I get great gas mileage
I about soaked the engine around the intake (even the back) w/ carb cleaner while holding the throttle at 2000 rpms and at idle. No changes so I don't think it is an air leak.
I went ahead and changed the air temp sensor since it was cheap. I had to replace the A/C exterior temp sensor when I got it as it was reading low (40 to 60 degrees) most all the time; so thought maybe it was not reading correctly.
I poured another can of seafoam into the intake thru the pcv valve port and killed the engine and continued to pour. Will let it soak overnight.
Will let you know how it does going to work in the morning.
Hope it was either the temp sensor or carbon.
If not, it will have to go to the shop for checkout.
Will see what it does at 70 degrees this afternoon.
Maybe either the seafoam overnight soak or the air temp sensor solved it.
By the way - not a lot of smoke this morning when I cranked it up. Fair amount right at first but it cleared up by the time I got out of the driveway.
I thought for sure you would of had a disco room full of smoke on the dance floor
That air temp sensor is starting to sound like the culprit. I'll be very interested in your afternoon drive home.
I am beginning to think it was the temp sensor in the air intake bridge.
Just put that old temp sensor back in and see if the symptoms come back. Unless you do,,you will always wonder which one it wasBC
No more pinging that I can tell.
Will still pull the same two plugs and see what they look like.
I have never heard of plugs causing a lean condition. Sure, the can foul or not burn hot enough but bad plugs burning too hot? Any of the other guys having the problem got new plugs in?
I am wandering if the fuel pressure is off a little. Would that not throw a code though?
Why would the o2 sensors not richen it back up since they should be sensing a lean condition?
A plug can cause pinging if it has hot spots on it--(old carbon or a nick on the strap--or near the threads on the end---
The 02's will richen up a lean fuel condition in closed loop up to plus or minus 25% before throwing a code--so lots of lee-way there
A sanner will read fuel pressure-closed loop LTFT's or called fuel trim sometimes--a positive number means a lean condition and a negative number means a rich condition---IAT temp---ECM coolant temp --actual timing---actual KR--Commanded AFR--so many useful tuning aids, short of having a data logger from a tuner like EFILIVE or HPTuners
I had some light pinging at part throttle too--couldn't find anything tht seemed out of whack--other than old plat. plugs with 60K on them--So I swicthed them to TR55's and gapped them at 40 --and the pinging disappeared. I do have a heads/cam combination and the .040 gap was reccomended to me by Thunder Racing .Also here in calif we have SH--t gas only 91 octane---My old plats. were clean but had some spots that looked like they got hot on he strap---I'm glad the IAT sensor seemed to have worked for you !!!!! On my combination I "0" out the entire IAT table as i found it to report erroneous temps all the time--It was always around 140*--cooled down a bit after running about 60 MPH for awhile--I think it reads the under-hood temp and bridge temp rather than the incoming air temp.
I did pull the same 2 plugs and they are browner now. No more pinging on 93 octane. I tried a little 87 and it started pinging (was low and only put 5 gallons in as a test). Immediately filled up w/ 93 and no issues.
I will probably pull and change the plugs at 50k miles. Only 39k now on them.
He is going to change out the Iridium sprak plugs and replace then with NKG plugs to see if that will help. I told him it may be "the temperature sensor".
So if you say you tried the switch and the ping came back..then I would think I have the same problem..
BTW new heads are installed and the tops of the pictons were cleaned off while the heads were removed...so I don't believe that Sea Foam is needed at thie point.
Thx..
I have no pinging anymore w/ 91 octane fuel or better.
I have a very slight pinging still at just the right amount of throttle (about 1/4) and the right amount of load (slight hill climb) w/ 87 octane fuel.
The temp sensor is cheap and well worth the try.
