coolant temp question?
Old Apr 19, 2007 | 05:28 PM
Marcs c5's Avatar
Marcs c5
Default coolant temp question?
At what coolant temp would you consider a problem? (2003 Z06)
Old Apr 19, 2007 | 05:35 PM
vettenuts's Avatar
vettenuts
If its stock, it can hit 230 easy.
Old Apr 19, 2007 | 05:40 PM
Marcs c5's Avatar
Marcs c5
well, thats what my car hit today(230). I guess I dont have a problem then. The car is stock with about 17000 mi.
Old Apr 19, 2007 | 06:41 PM
max'svette's Avatar
max'svette
St. Jude Donor '11
On the freeway it should be around 170-190. In town or while idling 200-230 tops. After that I would start checking things .
Old Apr 19, 2007 | 06:46 PM
vettenuts's Avatar
vettenuts
If I remember correctly, the fans don't come on until 228. I ended up buying a Vinci fan switch and set it to come on at 208, off at 201. It only comes on in traffic and with the stock thermostat allows the oil to reach a good temperature.
Old Apr 19, 2007 | 06:56 PM
NOS500's Avatar
NOS500
Old Apr 19, 2007 | 08:44 PM
corvettedoug's Avatar
corvettedoug
If it is only heating up sitting in traffic, check for debris in front of the radiator and a/c condensor.
Old Apr 20, 2007 | 08:11 AM
99 vett babycar's Avatar
99 vett babycar
Old Apr 20, 2007 | 08:13 AM
I'd be concerned at 235 degrees or above. Good idea to check the radiator area for debris.
Old Apr 20, 2007 | 08:16 AM
happa's Avatar
happa
or it might be your thermostat going bad too. You can always get a cooler thermostat and have a tuner just reset your fans. Im running the 160 and sitting in traffic at 85 degrees (for about 20 mins) and it never got over 180. Good Luck
Old Apr 20, 2007 | 10:55 AM
Marcs c5's Avatar
Marcs c5
I will do this tonight. I cleaned it once before but I hear its like a big vacume that suck up everything in its path. Maybe its dirty again.
To coolant temp question?
