Callaway honker Problem
Old Apr 21, 2007 | 06:58 PM
SSquid's Avatar
SSquid
Default Callaway honker Problem
I installed this on my 03 Z06... for starters it was a PIA to install... 2nd... I am throwing code P0102 and the engine at first didnt want to idle for like 2 seconds when it started up... then I got the code... so I took it out to see how it felt and it feels sorta bogged down a little? it doesnt even spin a tire at all all through first when once the power band kicked in stock it would squeel a bit... and if I quickly tap the gas you hear the huge suck of air... then the rpms shoot up... like a half a second after... you would think it would rise as you hit the pedal... any info?
Old Apr 21, 2007 | 07:24 PM
vettenuts's Avatar
vettenuts
I believe the 03 Z06 was a screenless MAF. Any CAI will disrupt the flow enought to throw that code. Likely, once thrown, you may be in the backup speed density mode. I seem to remember the fix is to get the LS1 MAF that has the screen in it. If you know anyone local, you can try and see if this corrects the code prior to spending any money on it but as I remember this is fairly common with the screenless MAF.
Old Apr 21, 2007 | 08:07 PM
SSquid's Avatar
SSquid
the flow arrow should be torwards the damn throttle body correct? Screw this ****... this honker **** has pissed me off... taking this thing off... right now as we speak and putting the stock one back in... but now I have this giant hole where the honker went on my shroud... guess I will be ordering a new one.... I bet that piece of plastic is 100 and some dollars
Old Apr 21, 2007 | 10:01 PM
Sleazy Rider's Avatar
Sleazy Rider
Veteran: Marine Corps
i put on the honker and started getting a p1514 code ( airflow to tp sensor correlation high ) which would send the car ( 03' Z ) into limited power. sounded like the car was on a stutter box. last saturday i removed the honker and put the stock one back on, new air filter element and cleaned the maf with throttle body cleaner and so far no codes. and i have been making it a point to drive the car everyday and get on the highway as much as possible.
Old Apr 21, 2007 | 10:07 PM
Vette Ed's Avatar
Vette Ed
CI 4-5-6-7-8-9-10 Veteran
St. Jude Donor '07-'09
i bought mine for approximately $32.00 at a dealer.
Old Apr 22, 2007 | 12:18 AM
jtkeller's Avatar
jtkeller
St. Jude Donor '07
No problems with my honker on an 03 z06
Old Apr 22, 2007 | 08:04 AM
D2Brewing's Avatar
D2Brewing
No problem with the Honker and a screenless MAF on my '02 vert...
Old Apr 22, 2007 | 11:14 AM
mcv's Avatar
mcv
We're very disappointed to hear about your situation. If you'd like, you can call us and speak with a technician or an engineer about your installation. There's probably an easy solution to the problem. We can go through it step by step with you.
One of our factory test cars was a 2003 Z06 and we're very familiar with the application. Honker installation should not trigger trouble codes. There's about 20 hp to be gained with an otherwise-stock '03 Z06. More as soon as you add other performance parts.
Let us help you fix the problem. Please call us at 860-434-9002, 8am - 5pm, eastern US time, Mon - Fri.
Old Apr 22, 2007 | 03:36 PM
Dan_the_C5_Man's Avatar
Dan_the_C5_Man
the flow arrow should be towards the damn throttle body correct? Screw this ****... this honker **** has pissed me off... taking this thing off... right now as we speak and putting the stock one back in... but now I have this giant hole where the honker went on my shroud... guess I will be ordering a new one.... I bet that piece of plastic is 100 and some dollars
I won't take your forum nick-name literally for now. I suspect an installation issue of some sort, i.e. un-metered air entering the engine. Let Callaway help you; I assure you this is the highest-quality aftermarket intake available for a C5, period.
Old Apr 22, 2007 | 04:09 PM
SSquid's Avatar
SSquid
well I def. didnt get 20hp... i lost about 200hp from the feel of how it is running... I already took this thing out... and I will call you guys monday but I have a feeling I wont get anything out of it...
Old Apr 22, 2007 | 06:10 PM
vettenuts's Avatar
vettenuts
I agree with Dan, I had a Donaldson, Vararam and now the Honker. The Honker is my last CAI and a keeper. Very good quality, excellent filter size and fit, as good as OEM. I would call Callaway and hopefully they can help you out.
Old Apr 22, 2007 | 06:47 PM
hotwheels57's Avatar
hotwheels57
...probably not with the negative attitude that it can't be fixed. I can't recall anyone else posting that they had issues with theirs, so you'd be in a small minority if the issue can't be resolved. Keep an open mind and you'll find success.
Old Apr 22, 2007 | 09:10 PM
nonsuchpro's Avatar
nonsuchpro
I know this doesn't really help you but I had my honker installed 2 months ago at a reputable corvette shop. I'm not sure if they got codes and dialed them out but I haven't thrown any yet on my 03 AE coupe.
TTT
Old Apr 22, 2007 | 10:02 PM
Vassili's Avatar
Vassili
PM'ed you....
To Callaway honker Problem
