I need piston and deck cleaning tips.
Old Apr 22, 2007 | 02:41 PM
RED99's Avatar
RED99
Default I need piston and deck cleaning tips.
I just pulled my stock LS1 heads off, and the bottom part of the head gasket is stuck to the block. What's a good chemical to losen up the bond so I can scrap it off with?
And is there anything that works good for cleaning the carbon off the top of the pistons?
Old Apr 22, 2007 | 04:37 PM
BrianG01's Avatar
BrianG01
seafoam is good for carbon
Old Apr 22, 2007 | 05:02 PM
double-oh-coupe's Avatar
double-oh-coupe
I didn't use any chemicals to get the gaskets off ... I used a plastic ice scraper and a plastic light switch cover to scrape off the old gasket.
Old Apr 22, 2007 | 06:10 PM
dgrant3830's Avatar
dgrant3830
Wounded Warrior Escort '11
Good old fashioned razor blade with a holder.
Old Apr 22, 2007 | 06:32 PM
vettenuts's Avatar
vettenuts
I used a bamboo chopstick that was ground to a chisel shape. Won't scratch aluminum and took off gasket and carbon for a final mild cleanup. Be very very very careful of your lifter area you don't get anything in there. Cover them up when doing everything else. I was super careful and for the heck of it I used a borescope to look into the oil gallery and I found a piece of gasket that got by my rags and everything. That would have wreaked havoc and I am wondering if this may be a reason a lot of guys spin bearings after a head change.
Old Apr 22, 2007 | 07:31 PM
Jeff @ TPE's Avatar
0Jeff @ TPE
Former Vendor
St. Jude Donor '06 & '12
A worn light scotchbright pad.. Be very gentle..
Old Apr 22, 2007 | 07:51 PM
bennettrp's Avatar
bennettrp
St. Jude Donor '06-'07-'08-'09-'10,'13-'14,'19-'20-'21-'22
Old Apr 22, 2007 | 08:48 PM
jers98vet's Avatar
jers98vet
Lacquer thinner and an old grey scotch brite.
Jer.
Old Apr 22, 2007 | 08:50 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
For the block deck I used a plastic ice scraper first, then a scotchbrite pad, then a large flat honing stone.
The pistons I used a wire brush cup on a die grinder (each one done at TDC).
Old Apr 23, 2007 | 12:13 AM
RED99's Avatar
RED99
Lots of good ideas. Thanks everyone.
To I need piston and deck cleaning tips.
