Bonehead move # 2
Old Oct 18, 2001 | 01:03 AM
C5Longhorn's Avatar
C5Longhorn
Default Bonehead move # 2
Well, I made my second bonehead move and cut a corner too tight, scraping my rear passenger rim. I checked the damage and its slight and not very noticeable. However, it did scuff and scratch and scrape off the clearcoat on the rim. Do I have to do anything to the high polish rim? Need to add clearcoat or is it ok as is?
Any help would be appreciated.
Thanks,
Old Oct 18, 2001 | 08:33 AM
C5Longhorn's Avatar
C5Longhorn
Default Re: Bonehead move # 2 (rschiltz)
TTT
Old Oct 18, 2001 | 10:01 AM
Paul R's Avatar
Paul R
Cruise-In I Veteran
Cruise-In II Veteran
I wouldn't describe this as a bonehead move, because more of us have done this than you would believe. It is part of using your vette. No car that is used will remain perfect forever.
I wouldn't try to re-clearcoat the damaged section. If the scars are detectable, you can buff them out with a buffing wheel and a dremel. Or contact a wheel refinishing/repair shop if it really bothers you. Keep a good coat of zaino on the wheel and it should be fine.
Or you can do what I did and just replace the wheels with some aftermarkets :D
Old Oct 18, 2001 | 10:10 AM
Scott97's Avatar
Scott97
Default Re: Bonehead move # 2 (Paul R)
Dang Rick, first you dropped stuff into the black hole and now this! j/k :)
Sounds like its not too bad.
You could always buy my magnesiums from me ;)
Old Oct 18, 2001 | 10:46 AM
chuckster's Avatar
chuckster
No prob.
I did it too! :mad:
Just buff it out with a Dremel or by hand and then put a coat of clear nail polish over it to keep it protected. No need to spray clear coat.
Old Oct 18, 2001 | 11:22 AM
glen5839's Avatar
glen5839
Rick
There's a good repair shop here in Houston near Antione and 34th off of 290. If you want to get it repaired let me know and I'll make a phone call for you.
Old Oct 18, 2001 | 06:14 PM
slogan_98's Avatar
slogan_98
Default Re: Bonehead move # 2 (glen5839)
If you are talking about the Wheels America place I didn't think they did very good work.
Steve
Old Oct 18, 2001 | 06:26 PM
Vet-Y2K's Avatar
Vet-Y2K
I hope it's not true that thinks happen in 3s. Maybe it's time to park it and drive something else untill the third thing happens. :confused: :confused:
Well a rim is okay could have been a lot worst. Just be a little careful for a little while till the bad luck runs its course. :) :seeya
[Modified by Vet-Y2K, 4:26 PM 10/18/2001]
Old Oct 18, 2001 | 07:55 PM
C5Longhorn's Avatar
C5Longhorn
Default Re: Bonehead move # 2 (Vet-Y2K)
Thanks everyone for the responses. Its not bad enough to warrant repair at a shop but I will try to file it down and add nail polish.
Scott,
What rims are you using now? You must be on your 4th set now :D
Thanks for the help offer Glen.
Old Oct 18, 2001 | 08:02 PM
JWSchmidt3's Avatar
JWSchmidt3
Hey Rick, the move wasn't bonehead, but telling the world on the CorvetteForum is. :p: :lol: :lol:
Old Oct 19, 2001 | 12:57 AM
C5Longhorn's Avatar
C5Longhorn
Default Re: Bonehead move # 2 (JWSchmidt3)
Yeah, I know but I was worried about whether or not I needed to immediately seal it or not. :confused:
To Bonehead move # 2
