Need some help with a window valet
Old Apr 29, 2007 | 06:53 PM
vettes4fun's Avatar
vettes4fun
Default Need some help with a window valet
I bought a used one off of a forum member and I can not get it to work. I can hold down on the reset and unlock buttons and get it to go into the mold and thats it. I want my windows to go up and down no more than that, if possible. I think I'm going it right but I can not get the horn to blow and the windows to go down letting me know it's programed plus I do I get the pin number . I have a 97 vette that I'm putting it on. Help please
Old Apr 30, 2007 | 10:00 AM
waupachino's Avatar
waupachino
The PIN is the last four digits of the serial number. Here are the instructions for the window calibration:
You'll press '4' on the DIC to enter the configuration
menu.
Under the '4' option, there's four more items:
1 - configure windows
2 - configure door locks
3 - configure accessory power
4 - restore factory defaults
You'll press '1' on the DIC to access the window
configuration options.
Under the '1' options, there's four more items:
1 - disable
2 - enable and calibrate
3 - window up strength, normal
4 - window up strength, strong
You'll press '2' on the DIC to enable and calibrate the
windows. This option requires a pin number. The last
paragraph of the disclaimer describes the relationship
between the PIN number and the serial number. The
serial number is on the disclaimer page and on the unit.
You can find complete instructions here: http://www.topdowntech.com/documents/WV-100.pdf
