Injector Upgrades
Old Apr 29, 2007 | 11:37 PM
PewterMetallic98's Avatar
PewterMetallic98
Default Injector Upgrades
What would you guys said would be the most inexpensive route to upgrading from stock injectors?
Old Apr 30, 2007 | 06:02 AM
vettenuts's Avatar
vettenuts
If you need bigger injectors, depends on how big. The 30# Ford SVO's are popular and fairly inexpensive. You can find them used fairly frequently as well.
Old Apr 30, 2007 | 09:51 AM
davidfarmer's Avatar
davidfarmer
The ls6 injectors are a tiny bit larger, and should be easy to find a good set. I know I've tossed several sets.
the GM turbo injectors are really good. These were used in the Turbo Trans Am, and are used in the ASA race engines, and I ran them in World Challenge.
Old Apr 30, 2007 | 09:52 AM
PewterMetallic98
That sounds a lot better than throwing a ford product in my corvette!
Old Apr 30, 2007 | 10:43 AM
TYSON1997's Avatar
TYSON1997
you have a 98 so you have the biggest stock imjectors for a corvette already. Then you have a return style fuel system. I would just buy an adjustable fuel pressure regulator and bump it up to about 70 psi from 58. They will flow another 3# or so at 70. It suprisingly takes quite a bit to max out even the stock injectors on a 97-98.
Old May 27, 2007 | 10:18 PM
Brad@RevXtremeAutoSports's Avatar
Sorry for the stupid question but where doe this get mounted at and on which line? pics or write up? Also which regulator is recommended?
Thanks for the help
Brad
Old May 27, 2007 | 10:55 PM
DRIVER456's Avatar
DRIVER456
From: NY- 2013 Corvette Challenge Champion-2013 Index Combo Champion 2015 CC/MM Champion
St. Jude Donor '07
If you look inbetween the 2 fuel lines above the fuel injector,That silver cylinder looking thing is the pressure regulator.The one in that picture is adj.It takes the place of the stock one.............Paul
Old May 28, 2007 | 09:45 AM
Rex99Coupe's Avatar
Rex99Coupe
Patches has this write up for Fuel injector upgrade.
http://forums.corvetteforum.com/show....php?t=1060573
Old May 28, 2007 | 11:03 AM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
^^ These are an excellent choice - but a bit pricey. They're the GTP Bosch injectors part# 0 280 155 868 (Bosch part #). They flow 39.89 lb/hr @ 58.02 Psi (4 Bar).
Product info is available from Bosch Motorsports pdf. - give me your email and I'll send you a copy.
Best reason for using these.....GM has derived the offset tables for these injectors as they are used in the ASA cars and World Challenge cars. These tables are important for proper tuning - especially idle and AFR.
fwiw.
Old May 28, 2007 | 11:28 AM
Bob K's Avatar
Bob K
St. Jude Donor '11-'25
Default Why Injectors
Based on your profile, I don't think that you will gain anything from upgraded injectors.
Are you planning upgrades in the future?
Bob K.
To Injector Upgrades
