Brake fluid
Old Apr 30, 2007 | 04:29 PM
BATM4N's Avatar
BATM4N
Default Brake fluid
Can someone confirm that the book recommends using Dot 3 brake fluid and not Dot 4? I have a 98 vert. Thanks
Old Apr 30, 2007 | 04:40 PM
MattB's Avatar
MattB
http://www.gmpartshouse.com/
FYI, They have the owners manuals for free download.
But, yes DOT3.
Last C5's Avatar
Last C5
Dot 3 is fine if you're not driving the car hard and experiencing brake fade. If you are then go to a DOT 4, most of them are compatible with the DOT 3s. I run ATE Super Blue DOT 4 in both the brakes and clutch.
Old Apr 30, 2007 | 04:47 PM
Bill Dearborn's Avatar
Bill Dearborn
DOT 4 exceeds DOT3 and is OK to use. Do not use DOT 5 Silicone fluid since you will trash your brake system.
Bill
Old Apr 30, 2007 | 05:42 PM
TEXHAWK0's Avatar
TEXHAWK0
DOT 3 fluid came in all the C5s, up to and including the 2004 models.
I still use DOT 3 in my 04 Z06. DOT 4 should be compatible, but I don't want to mix them until I need to completely flush the brake system.
Old Apr 30, 2007 | 05:57 PM
rws.1's Avatar
rws.1
You can use Valvoline Synpower DOT 3 & DOT 4 brake fluid .
It is compatible with ALL DOT 3 or DOT 4 fluids...
No reason to drain....
I have been using it for the past 3 years in both my Vettes.. over 20K miles... No issues...
I do about 6 Auto-X weekends a season.
Old Apr 30, 2007 | 08:33 PM
T VETTE's Avatar
T VETTE
Old May 1, 2007 | 01:49 AM
BATM4N's Avatar
BATM4N
Thanks for all the replies
Old May 1, 2007 | 01:05 PM
berryj's Avatar
berryj
I'm getting ready to do some track action and will need the ATE superblue. I've gone to 4 different auto stores and no one has it. Is this an internet deal or are there any local stores that typically carry it?
Old May 1, 2007 | 01:08 PM
AU N EGL's Avatar
AU N EGL
ATE Superblue and ATE 200 will need to be ordered. anothe choice is Motul 600. Porsche dealer or Porsche aftermarket tuner may have them as well.
Old May 1, 2007 | 01:13 PM
Last C5's Avatar
Last C5
I use a fake mustash and glasses to go in and buy it from the local BMW/Audi/Porshe repair shop. A lot of the foreign shops carry it.
Old May 2, 2007 | 01:08 PM
berryj's Avatar
berryj
Thx for the advice. I'll check on it and my local NAPA guys offered to acquire this stuff for me and research it. We'll see if they can come through on it.
Old May 2, 2007 | 01:51 PM
AU N EGL's Avatar
AU N EGL
Go to a motocycle shop. More of a chance they have it then a big parts store can get it.
Old May 3, 2007 | 09:02 AM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
In a mild climate like SoCal, DOT4 is a better choice (higher boiling point and slightly higher viscosity). The Castrol previously mentioned or Wilwood EXP are good choices.
You'll appreciate it on the SCMRs!
Old May 3, 2007 | 09:24 AM
Secret237's Avatar
Secret237
I use Castrol GT LMA DOT 3 and DOT 4.
The main problem with brake fluid is that it absorbs moisture from the air. The LMA in it's name means Low Moisture Absorbition.
This fluid used to be the best you could buy, years ago, it's still pretty good as far as boiling point goes, not the best now thought, but the reason I like it is it's based on vegtable oil, which I think is very good on things inside your brake system, like O-rings.
To Brake fluid
