Help -- first to second shift
Old May 2, 2007 | 04:01 PM
drbvac's Avatar
drbvac
Default Help -- first to second shift
Anyone notice if when the transmission is cold it is hard to shift from 1 to 2 straight back? Seems like it wont go into gear, drops into third with some pulling and then it will go back into second. After I drive the car for a while it doesn't seem to do it?
Old May 2, 2007 | 04:28 PM
87SAM's Avatar
87SAM
I’m the furthest thing from a tranny expert but maybe a fluid change is in order. I do not experience this phenomenon in mine. How cold are we talking?
Old May 2, 2007 | 05:06 PM
rcs128's Avatar
rcs128
I assume it's not CAGS interfering, right?
Old May 2, 2007 | 05:31 PM
AuburnShrink's Avatar
AuburnShrink
That was my first thought as well........
Old May 2, 2007 | 10:01 PM
Ol'55's Avatar
Ol'55
From: Southern New Jersey, The wet part at the bottom
St. Jude Donor '08-'09-'10
Me too.
Old May 2, 2007 | 10:06 PM
versacestl's Avatar
versacestl
What is CAGS?
Old May 3, 2007 | 03:17 PM
kevin40zx's Avatar
kevin40zx
Originally Posted by versacestl
What is CAGS?
That annoying 1-4 shift. Gate blocks 2nd gear under light throttle.
Old May 3, 2007 | 03:24 PM
HawkIVette's Avatar
HawkIVette
What is CAGS?
Computer Aided Gear Selection
Old May 3, 2007 | 03:50 PM
Bill Curlee's Avatar
Bill Curlee
CI 6,7,8,9,11 Vet
St. Jude Donor '08
Recommended changing the tranny fluid. If you have a later model C5, consider up-grading to synthetic ATF. It will make a big difference.
BC
Old May 3, 2007 | 04:07 PM
garllo's Avatar
garllo
I would first change the transmission fluid. If there is only a marginal improvement or no improvement then follow the proceedure in the link below.
http://rpmtransmissions.com/files/c5...adjustment.pdf
the only time consuming thing here is removing the console. It's not hard to do just time consuming!
Old May 3, 2007 | 05:38 PM
JWB ZO6's Avatar
JWB ZO6
St. Jude Donor '06-'07
BC
It did for mine
Old May 3, 2007 | 05:45 PM
LF97C5Vette's Avatar
LF97C5Vette
Your first thought should not be CAGS if/when the OP mentions "When Cold" because CAGS doesn't come on unless the coolant temp is like 170+...
I also have this problem, sometimes 2nd gear is pretty tough to get into in the morning... I mean, i'll poke out onto the road in 1st... then pull back into 2nd, and it'll kinda pause for a second, then slowly slip in... but after the first couple shifts it goes away... and it's long gone by the time the car is warmed up...
'97 C5 MN6
Dan
To Help -- first to second shift
