99 with battery less than 1 year old (I know it could still be bad).
When I disconnect the battery I get a pretty good arc. The headlight actuators make noise and rotate. (don't know if that's normal or not)
Bottom line, if It sits for a day, it won;t start.
Should I start pulling fuses until the ark stops when I connect the battery?
Where is the best place to start? or
Can you recommend somebody in St.Louis to take it to?
Larry
Connect an amp meter in series with your negative battery cable, at rest you should be reading 20mA anything higher, start pulling fuses till you get a 20mA reading. That would be alot easier and safer then watching the arc...
I would obviously start with the headlight motor uses! LOL
Are you disconnecting the positive battery cable to see this arc?
If so thats extremely dangerous, you should always disconnect the negative cable first.
And using an amp meter will tell you exactly how much of a draw, which in turn should help you narrow it down. If it dies after sitting just a day, its got a pretty good draw. Its more that your interior lights staying on.
Had same issue last month and traced it to the driver side power seat control. Would drain battary in 1 to 2 days. Changed out seat control and all is fine.
You CANT just stick an amp meter in the circuit and expect to see 20 ma! The BCM will go active when you connect the circuit and turn on all sorts of stuff. The first reading you will see will be around 7 - 8 amps. Then as the BCM starts to shut things down it will drop down in steps until about 3-5 mins later when the BCM goes into the security mode. MAKE SURE that you disconnect the hood light! If it's right close to 20ma, your good to go! If you open the door, the BCM will need to cycle back to the security mode to get the correct reading.
There are things that get stuck on.
Seat control modules, Headlight control module, etc...
There are a bunch of post on this in the search files.
Here's my take on this and it is definitely worth at least checking out for your situation...
I have a relatively new battery and a while back, the car would sometimes start and other times not start. When the car did not start, it appeared as if the battery was dead. So what gave?? I had the battery tested and I also tested to see if the alternator was working. All passed with flying colors.
In my case, it turned out that the battery connection was the problem. It turned out I had to tighten the battery cables really good. Now here's the thing... the battery cables were not loose to a point where they were dangling, the connector screws were just not really tight. After tighting up pretty good, no more problems. I suspect if I were to clean terminals on the battery cables with a dip in baking soda and water, I might not need things so tight. All I know is ever since I cinched the cables to the battery really well, no more problems.
Thanks all.
It all started with the driver seat moter stuck. I have noticed in the past that it does that when the battery is low? I have removed the fuse for the seat motor (#4 on the inside box). I have been removing the negative cable. I agree with the post that many things actuate when the circuit is first connected and wasn't sure if the headlights was normal. I had the automatic lights on and turned them off, as well as entry and all I could find that might cause this.
So how do I test for drain after all has settled down?
Connect the meter from where to where?
Larry
My drivers side power seat was on all the time & adjusting ---Battery kept going dead--- unplugged it under the seat all is fine---under the seat i thought was better so I could change it easier if I had to without opening hood---
Disconnect the neg battery cable. Connect an amp meter between the neg terman and the neg cable.
It doesnt matter with the polarity. It will just read NEG or POS after the reading. You are just interested in the at rest/sleep reading. That will happen after about 5-10 min after connection of the ampmeter. Yes the headlights will jump when it first connected.
Follow uo on my problem:
It was not the head light motors.
It was corrosion on the positive battery post.
It is interesting that after correcting the problem it didn't arc when I connected the negative cable.
I'm also convinced that, at least on my car, the driver seat motor relay doesn't want to turn off when the battery is low.
Larry
